Nice Chrome Handlebar bar top Clamps Available
  • mmatches1
    • Sep 2012
    • 121
    • Alberta, Canada
    I heard that some were looking for a nice set of handlebar top clamps and I found a set that fit my 81 XS1100. They are available at both Mikes XS and XS650 Direct and the price is right.
    Shop Yamaha XS650 parts from XS650 specialists since 2010. Engine rebuild kits, carburetors, ignition and electrical components. Fast shipping. Fitment guaranteed.
    Chrome Custom handlebar bar top Clamp - with plated allen socket bolts.
    Fits: All 650's 1970-84
    Part #37-0002
    $17.95 CAD Ea
    Add to Cart
    81H Venture - hope to ride summer 2013
    79F Cafe Racer at Some Point;
    68 CB175 Sloper - Cafe Racer
    74 KZ400 - Restoration project nightmare
    62 BSA Super Rocket - In Pieces
    72 CB100 Super Sport - Not super or sporty but fun
    Problem there though is that the XS11 has the ignition switch also mounted in that clamp and the chrome one does not have the part for that switch.
      Got one on my Standard, chrome will start to pit rather quickly, nice looking piece though.
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        True ! And I had to put a little bit of a tiny worn out drill bit taped to each side of the bars where the clamp bites the bar, even though I cranked them down as hard as I dared. This kept them from turning in the clamps when braking hard, ( leaning on the bars would cause them to turn down under the clamps on the XS650 ), might be a better way but this worked for me.
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
          Just on Standards Natemoen.......
            Really? Guess I never knew that part was different between the standards and specials.
              Hey Phil,
              I've had mine on there for several years, still looks good, but mine is GARAGE KEPT!
              And it clamped down nice and tight on my bars just fine! But yep, if you have a standard, won't work because of the ignition switch, but specials are just fine.
                I have one of these. You need to throw your keys on the ring over the top or they rub the chrome off. Also, they don't grip the bars very well (at least at first), so be sure your bars will stay in position if you put down-pressure on them -- or your tank will be sad!
                  Hi Nate,
                  the Standard's ignition switch don't mount on that clamp, it sticks up through it so the chrome clamp simply leaves the switch out in the open.
                  Just like on a Special.
                  Where the chrome clamp won't work because the Special's bar clamps are spaced further apart.
                  • Dan Hodges
                    Sensei of Internal Combustion
                    • Sep 2004
                    • 526
                    • A garage in south St.Louis
                    Handle Bar clamps
                    Part #37-0002
                    $17.95 CAD Ea
                    Add to Cart
                    The (top) handlebar clamp for the original V-Max fits perfectly,looks beautiful, won't slip like most of the after market stuff and simply looks trick. You can even get the chrome push on bolt tops from Yamaha which really finishes it off........ultra cool.
