My right side aftermarket muffler had a clamp on it where it connects to the header. I could also see a crack on the underside just in front of the clamp that the PO had tried to repair with JB Weld or something. I took the clamp off and cleaned up the hardened putty and discovered a crack that ran 1 and a half times around the muffler and wrapped around the crossover. I welded it up and did some grinding, here it is:
[IMG]
[/IMG]
[IMG]
[/IMG]
I wiped some oil on it to prevent rusting for now but am wondering how best to save this? I have some High Temp Rustoleum Aluminum paint (2000 degrees). Will that adhere to the ground down weld? Putting the clamp back on will help cover most of it up but I don't want rust to take over.
Anyone else dealt with this and have any ideas for me?
[IMG]
[/IMG][IMG]
[/IMG]I wiped some oil on it to prevent rusting for now but am wondering how best to save this? I have some High Temp Rustoleum Aluminum paint (2000 degrees). Will that adhere to the ground down weld? Putting the clamp back on will help cover most of it up but I don't want rust to take over.
