Anyone ever have the #2 & 3 valves only bend on you?
Number 2 & 3 Valves
Number 2 & 3 Valves
78 XS1100E Standard
Coca Cola Red
Hooker Headers
http://i408.photobucket.com/albums/p...m/DSC00580.jpg
1979 XS1100 Special
http://i408.photobucket.com/albums/p...m/DSC00612.jpg
1980 XS Standard
http://i408.photobucket.com/albums/p...m/DSC01137.jpg
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgTags: None -
What is firing order anyways, 1, 4, 2, 3 or something?'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~ -
If it skips a cog on a sprocket, I would think that any valve associated with that sprocket is in jepardy. It would just depend on how tight the clearances are and how carboned-up the detents are on the piston crowns.Skids (Sid Hansen)
Bent Valves
Only one reason for bent valves - something was in the way when they were trying to open. The possible culprits are either a piston or the other valve in the same cylinder. Either way, it is a serious problem that needs to be diagnosed.
You need to verify proper valve timing (timing chain, cam sprockets), valve lash, and make sure piston valve reliefs and valves are clear of foreign material (carbon). Either way the head must come off. You will find the reason as you disassemble the top end.
Another (less likely) cause is if you had excessive rod bearing wear to where the piston is coming up too far in the bore.
MP1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
Valves
Yeah. Going to pull heads and will inspect. A shame because its a low mileage engine. Compression on 1 & 4 are 150 psi! I'm thinking chain jumped a cog cranking it in the shop. It's a total restore so no hurry!
Dale78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
1980 Valves
Anybody know a source for valve replacements. Been a while since I've been on here. Had an accident a couple of years ago and just starting to get back into the 1980 MNS project.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
You never said intake or exhaust, but I'll assume intake. Ebay or a fellow member would be your best bet. Andreas as well. New valves are not a necessity in my opinion.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Valves
Looking for both intake and exhaust.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
Thanks Phil!!78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
