Paint removal questions
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Okay, my G has a really crappy PO engine paint job.
    The PO had painted everything metal from the carb bowls down to the starter cover.
    Anyway, after a decade of use, most/some of this (enamel I think) has peeled/come off.
    I want to take it all off and get back to the aluminum look.
    I know that brake fluid is a great paint remover, but does it damage the almuninum?
    I was thinking about sand blasting, but then I'd have to figure out how to plug up all the holes, or do it one piece at a time. (I don't have a blaster (or compressor), but the Auto Hobby Shop on Base has an enclosure.)
    I just think that blasting would be better, but WAY time consuming considering the disassembly required, SO maybe some sort of spray on stuff, like brake fluid and washing it off with the hose may be easier.
    Any ideas for a budget minded fella?
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Might try a can of carb cleaner ? If it starts to bubble the paint then buy a bunch at WMart, protect anything you don't want to take the paint off of.
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • GLoweVA
      • Jun 2011
      • 1957
      Here's a preview of what I've got to work with:
      The Green Monster
      Got him in '04.
      Scarlet
      Got her in '11
      Hugo
      Cold weather ride
      • BradW87
        • Jun 2013
        • 15
        • Topsham, ME.
        Agreed
        Carb cleaner works great! I know from accidental pain removal in the past
        79 F
        • kjohnson
          • Aug 2007
          • 202
          • Wetaskiwin, Alberta, Canada
          Aircraft stripper works well too. I've used that a few times before.
          K. Johnson
          -1978 XS750SF - brought back from the dead with carb
          triple clean and boots
          -1982 XJ1100J - brought back from the dead by
          replacing motor after throwing #4 rod
          -1985 XJ750XN - shim job, oil change, ride. not bad for
          $500 including new rear tire.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            Brake fluid won't hurt aluminum. The brake calipers are made out of aluminum.
            It is rather expensive to use as a paint remover, unless you can have all the guys that bleed their brakes save the drainings.
            • lakecountrydave
              • Aug 2007
              • 384
              • Phoenix, AZ
              I have had great luck with aircraft stripper, but I have no idea how it will effect the aluminum.
              Dave
              1979 XS1100SF Special
              • BillyRok
                • Aug 2011
                • 421
                • Shortsville, NY.
                I've used aircraft stripper to remove the dull black paint from calipers, the paint was adhered pretty good but came off after letting the stripper work for several hours...didn't see any adverse effects on the aluminum. I bet it would take the flaky paint off your covers pretty quickly, then you can polish them up some...anything from the "aluminum look" to a mirror finish. The spray comes out as a light foam and is a little hard to control over spray if things aren't disassembled.
                Billy
                • BradW87
                  • Jun 2013
                  • 15
                  • Topsham, ME.
                  Aircraft stripper
                  The aircraft stripper sounds like a decent idea. Pretty sure aircrafts are made of aluminium as well so my bet it it would be safe. It a has been my experiance that any stripper is expensive
                  79 F
                  • cpmaynard1980
                    • Feb 2013
                    • 183
                    • Hampton, VA.
                    ive been using aircraft stripper on the kz. the guy painted everthing thick. It starts to bubble the paint quick. I think i git my spray on can from walmart.
                    1979 XS1100 Special. Nicely modified.
                    1977 KZ1000 needs everything!
                    1971 CB750 Nice Restomod Completed
                    1972 CB750 Got it going after 30 years. Getting turned into a old school bobber. Working on a title.
                    SOLD-1981 XS1100H What got me on this site.
                    1980ish virago 535. Room mate left it for rent money. lol.
                    1980 XS850 almost stock 20k miles.
                    1979 XS750 Parts bike no title.
                    1979 XS750 Cafe running,someone else can enjoy it.
                    RIP-1980 XS850
                      I've used the stripper on plenty of aluminum parts with no ill effect. I would definitely wrap anything you do not want stripped with foil or tape or plastic...something to keep the stuff off of it.
                      • Tat2demon
                        • Jun 2012
                        • 718
                        • Sioux Falls, South Dakota
                        If youre going to go with Aircraft I recommend getting the pail and brushing it on. Ive had better luck with that over the spray can.
                        Nate
                        78 XS11 "Matilda" 2H7 000364
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
                        • mmatches1
                          • Sep 2012
                          • 121
                          • Alberta, Canada
                          Acetone is an effective paint remover and I learned this the hard way after spilling some on a tank. However it stinks and evaporates quickly.
                          81H Venture - hope to ride summer 2013
                          79F Cafe Racer at Some Point;
                          68 CB175 Sloper - Cafe Racer
                          74 KZ400 - Restoration project nightmare
                          62 BSA Super Rocket - In Pieces
                          72 CB100 Super Sport - Not super or sporty but fun
                            • 4015
                            DO NOT GET AIRCRAFT REMOVER ON YOUR SIDECOVERS! It will literally melt the plastic. Don't ask me how I know!
                            • clcorbin
                              • Jan 2010
                              • 495
                              • Albuquerque, NM
                              The last bike engine I saw stripped was done with "sand blasting" using crushed walnut shells instead of sand. It worked well if you have access to a good sand blast cabinet.
                              -- Clint
