First off thanks to this site I've finally got the bike back together and running. I bought this as a project back in March. Discovered the bottoms end was shot and lucked out to get a cheap parts bike.
First off I'm using an 80 special case, advances, and tic box with the good 81 top end. I'm running the K&N pods, dynajet stage 3 kit, and a four into one exhaust. I fired her up for a short ride the other day got back and realized the no. One cylinder is cold. I spent the other day trying to track down the problem and would like some advice as to where to look.
I confirmed the vacuum advance is working. The tci box is good. Mechanical advance wires are good. I also tried a different set of coils with no change. Swapping plugs and/or wires and caps make no difference. Good spark was confirmed with the colortune and also by grounding to the block. Compression was good in all four cylinders. I had previously cleaned all the carburetors and did again that day. I noticed the pilot jet was stripped in the carb body. I swapped everything over to a spare carb body I had and same problem. The carbs were all vacuum synced. Floats set at 23mm. Confirmed fuel filling the bowl with the drain and tubing method. Ive adjust the mixture screws on 2-4 with the color tune and get a great blue with a hint of yellow combustion. Nothing but the spark on 1. Before I decided to call it a night I took off the pod filter on one while it was running. When I put my hand over the throat I felt some fuel come up through the carb. There was a strong yellow combustion showing on the color tune then for a bit then back to just the spark.
I'm assuming that this points to the carb as the problem? Pilot jet circuit maybe? When I pulled the pilot jet out and let it soak in cleaner it seemed to be clean. It's got the six holes in the side and the tip appears to be solid.
Any help would be greatly appreciated as I'm supposed to be taking this baby on a road trip in two weeks and would much rather be on this for a long ride than my lil magna!
