Pilot Jets?????
    Just to be clear, synching is done wiht the synch screws only. The mixture screws can adjust vacuum, but it will be a subtle change, nothing like the change of adjusting the synch screws.
    • spayne83
      • Jan 2013
      • 159
      • Campbell, CA.
      Carb Sync
      I used this to sync the carbs
      It has a plastic screw valve to limit the vacuum oscillations that the gauge shows so I tightened it down so that the needle was steady but still moved when throttle was applied.
      I just rebuilt the carbs and I didn't see any of the previous tips broken off and I only snugged down the idle mixture screws down to finger tight where I just started getting tension and then backed them all off 2 turns. However no matter what I did with the screws there was absolutely no change in the vacuum.
      When riding it is sluggish off idle and then picks up around 3-4000 rpms but will start popping around 6-7000 and there is no increase in power from 1/2 throttle to full throttle, so I think that I am running really lean.
      79 SF 3H3 Engine, 145/45 Mikuni Jets, El Cheapo Pod Filter Mod w/ EMGO Pods, Coil Repower w/ Dyna Coils, Accell Wires and Side Gapped Plugs, 78 Mech Advance, 4-2 Turnouts
        Hey Spayne,
        Okay, you said POD filters, what type..inexpensive EMGO generic cones, or the fancier XS brand from MikesXS or Partsnmore.com? And how do you have them mounted to the carbs...directly or with velocity stacks/tubes?
        The cheap EMGO filters have prominent mounting lips that interfere with the air flow to the inlet bell ports...and cause problems around the 6krpm.
        You said you just rebuilt the carbs....but your symptoms sound like a clogged pilot jet circuit! Did you use carb cleaner and spray it thru the pilot jet tower and ensure that it came out the pilot jet screw hole as well as the little holes on the inside/underside of the engine side of the carb throat??
        Tweeleft, glad you found the possible problem with the pilot jets, hopefully with the right size, it'll behave better. Let us know what happens.
        • spayne83
          • Jan 2013
          • 159
          • Campbell, CA.
          They are the cheap filters, but I spaced them out from the opening about 1/4" so there should be air flow. I will be ordering a stock air box to get the velocity stacks to mount the filters.
          I soaked for at least a day in Yamalube and I did spray out everything, but I am going to rejet with 145 mains and 45 pilots (per a suggestion in another thread) and double check my float height, so I will spray that passage out again and check my plug color.
          • tweeleft
            • May 2009
            • 110
            • Bend Oregon
            Ok. This forum is outstanding. I've learned how to colortune,sync, read plugs,jetting carbs, and a s''h lot more.
            Update:
            Replaced 45 pilots with 42.5s
            Replaced 142.5 mains with 137.5s(may go to 140s)
            Set needle clip one notch rich
            Idle screws at 2 turns ish
            Test ride had to feather throttle or she would cough once rpms she was ok.
            Back in the garage. Colortune,sync. Reved off idle with colortune got mix screw on the sweet(I HOPE lol). Damn raining
            Will do test ride soon
            Keep the shiny side up
            1979 XS1100SF
            Mac 4-1
            Drilled airbox Uni filter
            Vmax bars
            Virago 1" shorter shocks
            30K miles
            http://i1228.photobucket.com/albums/...429_135845.jpg
            1981XS1100SH
            '80 G Forks and Triple Tree
            '80 G tank
            Mac Turnouts
            Virago 1" shorter rear shocks
            SH Headlight
            http://i1228.photobucket.com/albums/...psd6adaae1.jpg
            61 Wife
            83 Son
            86 Son
            89 Daughter
              • 5061
              Go back to the middle clip on the main needle setting. They are adjustible but the adjustment settings are too extreme.
              • tweeleft
                • May 2009
                • 110
                • Bend Oregon
                Ok tank is still in tuning mode
                1979 XS1100SF
                Mac 4-1
                Vmax bars
                30K miles
                1981XS1100SH
                '80 G tank
                Mac Turnouts
                SH Headlight
                61 Wife
                83 Son
                86 Son
                89 Daughter
                • tweeleft
                  • May 2009
                  • 110
                  • Bend Oregon
                  Good test ride. Didn't lower the slide needle clip but will. She sputters a little just before wot. Thinking that's probably it. Hope to do this weekend
                  1979 XS1100SF
                  Mac 4-1
                  Vmax bars
                  30K miles
                  1981XS1100SH
                  '80 G tank
                  Mac Turnouts
                  SH Headlight
                  61 Wife
                  83 Son
                  86 Son
                  89 Daughter
                  • spayne83
                    • Jan 2013
                    • 159
                    • Campbell, CA.
                    Not sure if you have seen this:
                    Hope it helps
                    • mikubuilder
                      • Jul 2011
                      • 548
                      • Westland, Mich.
                      Put some Seafoam in your gas for a couple of gas fill ups, that should clear up anything you've missed in the carbs
                      Nick
                      1982 Virago 750 (it's alive!)
                      • tweeleft
                        • May 2009
                        • 110
                        • Bend Oregon
                        Originally posted by spayne83
                        Yes I've seen this. As to why I'm doing the slide needle adjustment next. Thx
                        1979 XS1100SF
                        Mac 4-1
                        Vmax bars
                        30K miles
                        1981XS1100SH
                        '80 G tank
                        Mac Turnouts
                        SH Headlight
                        61 Wife
                        83 Son
                        86 Son
                        89 Daughter
                        • tweeleft
                          • May 2009
                          • 110
                          • Bend Oregon
                          Seafoam is on my list. Thx
                          1979 XS1100SF
                          Mac 4-1
                          Vmax bars
                          30K miles
                          1981XS1100SH
                          '80 G tank
                          Mac Turnouts
                          SH Headlight
                          61 Wife
                          83 Son
                          86 Son
                          89 Daughter
