I got the blade type fusebox from TC. My old fusebox looked rough but everything worked (for now). I got the fusebox today (THANKS TC!) and was looking at my old fusebox before I started. Here's a pic of it: (click to enlarge)
It's pretty obvious that this isn't the original fusebox and is some kind of fuse panel that has been cutdown. My question is, isn't there something going on with the MAIN fuse? I mean that's it in the lower left hand corner right? Fuse is there but sholdn't the two screws below has wires connected to it? If so, I guess it was moved. I have 4 fuses in this old fuse box as you can see and I thought there was 4 factory fuses plus a main. Before I start trying to track down some weird Main fuse hidden somewhere under the seat or on the frame somewhere, I was just wondering if there really is 4+Main or if it's 3+Main. Because if it's 3+Main then I guess my main has been redone into this redneck fuseblock I have on there now. I was going to move my main to the new TC fuseblock but now I'm not sure where it's at.
