Grease gun to remove stuck piston - Friggin' Awesome !
    • 3373
    Courtney, that's a big ROFLMFAO!
    Good to be able to give ourselves the credit for all the things we do and laugh about it!
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      Originally posted by Bonz
      I am a bit late to this party... Did the caliper not want to give up the piston by using the brake lever while still on the bike?
      If you have a partially-functioning brake system, using the master will work. But what do you do when the master needs rebuilding too? Do the brake rebuild piecemeal? Master first so you can get the pistons out? This is much simpler...
      And while this is messy, the mess is on your workbench. No worries about brake fluid on painted surfaces.... Pour some brake fluid in the banjo fitting before starting and most of the grease will fall out once the piston is out...
      • BradW87
        • Jun 2013
        • 15
        • Topsham, ME.
        Grease goes where?
        May seem like a silly Q, but what do you use to clean the grease out with after??
        79 F
          • 3373
          My way of doing it would entail wiping the majority of the grease out, remove the seals/rubber parts then rinse/brush the caliper in gas/kerosene or something similar. A spray of brake cleaner to finish with and it'd be one clean caliper.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
          • BradW87
            • Jun 2013
            • 15
            • Topsham, ME.
            Thanks!
            Thank you for your explanation!
            79 F
