I just recently put the carbs back in the bike & re-assembled the thing. Now is there something I missed after I re-hooked the throttle cable? Because when I turn to the right she revs up & to the left nothing. I put the cable in the clip above the carbs that's hanging i believe off the engine head. Any suggestions?
Routing of Throttle cable
Cabel
Reroute your throttle cable for the most slack in the cable housing. If you look closely you should be able to see where it is binding. turn handlebars in direction of bind and watch for cable movement to locate bind. Reroute as required. HTHUnless you are the lead sled dog the view never changes.
