Bike Popping through exhaust
  • crazy_ss75
    • May 2013
    • 8
    • Del City, Ok.
    My 79 xs1100 special pops through the left exhaust when I have it on main tank, but not on reserve. I have K&N filter pods and 4-2 exhaust with Harley mufflers. I have thoroughly cleaned and synced carbs. New plugs but #2 is fouled out after 50 miles of riding. Any advice on what I could check or fix would be appreciated.
    79 SF
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Any way you could link to a picture ? All I can think of is a plugged or blocked air jet but then why not on reserve too ? ? ?
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • crazy_ss75
      • May 2013
      • 8
      • Del City, Ok.
      What are you wanting a picture of, the whole bike? If you let me know what you want to see, i can get a pic posted
      79 SF
        May have a mal-functioning 'octy' if that valve and hoses are still intact on that special.
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          PLUGS to see what your dealing with ?
          76 XS650 C ROADSTER
          80 XS 1100 SG
            • 3189
            I have to ask which way the handle of the petcock is pointing when you are on reserve?
            • Gallaecus
              • May 2011
              • 251
              • East Haven Connecticut
              if your plug is fouled, youre getting too much gas or not enough air.
              doesnt seem like it would be related to your petcock position.
              maybe float level ? maybe worn rings ? maybe valve adjustment.
              or if it works good riding on reserve, screw it, ride that way.
              Steven
              1981 XS 1100 LH
              1979 XS 1100 SF
                • 3189
                I rode for many years thinking that the prime position was the off position on my 79SF petcock's. It was not until I joined this site that I found out differently. There are many things that can be wrong due to that simple mis-understanding including the symptoms he is mentioning.
                • crazy_ss75
                  • May 2013
                  • 8
                  • Del City, Ok.
                  Reserve is straight up on my petcock. There's no octy on it, I removed it because it leaked.
                  79 SF
                  • crazy_ss75
                    • May 2013
                    • 8
                    • Del City, Ok.
                    Top is #2, bottom is #1, #3 and #4 look like #1.
                    79 SF
                    • jjz28
                      • Apr 2012
                      • 1023
                      • Beckley, W. Va.
                      cant see pic.
                      77 XS750 2D completely stock
                      • crazy_ss75
                        • May 2013
                        • 8
                        • Del City, Ok.
                        Retrying Picture of Spark Plugs
                        Ok, this time left is #1 and right is #2. #3 & 4 look like one on left.
                        79 SF
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          Run a compression check on #2. If it checks OK, then put the plug from #3 into #2, and #2 into #3, and go for a long ride. When you get back, look at the plugs again. If #2 looks like it did before, and #3 looks better, exchange the plug boots on 3 and 2.
                          Go for another ride. When you get back, look at the plugs again. If the problem went to #3, it is the plug boot that is faulty.
                          If it still is #2, look at the plug wire, making sure that it does not get close to any metal portions of the bike. Tie it up with pastic tywraps if necessary. If that doesn't help, we'll think of something else.
                          Compression check first. Don't think you can skip it, it is the most important check at this point.
                          CZ
                          • crazy_ss75
                            • May 2013
                            • 8
                            • Del City, Ok.
                            I'll try that tomorrow. Have to rent a compression tester. I'll post results.
                            79 SF
                            • CaptonZap
                              • Jun 2010
                              • 1748
                              • Denver
                              Check with Checkers or Autozone, they may loan you one. Be sure that you hold the throttle open when you crank, and make sure that all plugs are out and laying on the head, wires attached, so that you don't burn out the coils. Or pull the big plug on the TCI.
                              Oh and yeah, get that car battery rigged up.
                              CZ
