XS1100H - Engine runs great but at 5 - 6000 rpm
  • XS1100H - Engine runs great but at 5 - 6000 rpm
    I just installed a set of rebuilt and cleaned carbs and fired it up for the first time today. I turned the pilot screws 1.5 turns. The engine starts right up and runs great but at 5 - 6000 rpm. I tried turning the pilot screw in and out with no change. When I turn the choke on it slows down for a bit but speeds up again. I checked for air leaks and can't find any. I am using an auxiliary gas tank and I have plugged all the vacuum fittings. I re-installed the 110 main jets and removed the rubber pugs as per instructions on the site and installed washers and o-rings on the pilot screw. Any ideas?
    81H Venture - hope to ride summer 2013
    79F Cafe Racer at Some Point;
    68 CB175 Sloper - Cafe Racer
    74 KZ400 - Restoration project nightmare
    62 BSA Super Rocket - In Pieces
    72 CB100 Super Sport - Not super or sporty but fun
    Just want to mention that there is slack in the throttle cable. I moved the linkage back when it was running and nothing changed.
      Idle screw all the way out? The big knob between 2 and 3.
      Intake boot clamp getting hooked on the #3 carb lever?
      Did you take your butterflies all the way out and end up putting on in crooked?
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        +1 on checking the idle screw setting.
          I will check the idle knob. I haven't adjusted it yet. I assume you mean the metal knob underneath between the block and the carb dead center between 2 and 3? I did do a bench sync. I looked underneath and couldn't find something any blockages.
            Try to uninstall your throttle cable and start your bike. I had the same problem 2 days ago. When I tryed with no cable the idle was good. I put the cable back and the problem disappeared.
            83 XJ1100
            06 FZ1 naked abarth
              Ok - I have a spare set of carbs on the bench and looked at how the idle screw works. I could not move the screw on the bike by hand and will try tomorrow with pliers. I assume I screw the knob in to reduce idle speed? Thanks
                Screw the knob out.....
                  Yep, think of it like a normal screw, Righty Tighty, Lefty Loosey. Tighter raises the RPM, looser drops the RPM.
                    Loosened the idle nut and she purrs like a kitten at 1100 RPM. Thank you for the help. Strange that I cannot remember tightening the nut. Now I will attempt to sync the carbs and the grand daddy of them all - color tuning!
                      Interesting how the sync involves the adjustment points and the idle nut. As I tried to sync 1&2 & 3&4 I had to loosen the idle nut because the idle shot up to 3000. It is running very nice after being synced.
                        Good to hear. Always nice when its something easy.
                        Nate
                        K+N Air Filter
                        88 Voyager XII
                        81 XJ650 Maxim
