I disassembled my XJ carbs for a thorough cleaning, soaking the rack in Pine-sol for a day and a half and cleaning everything else with carb cleaner. I have a few questions I'm looking for some help with, snapped some pics for clarification.
Should I replace this float? The edge of it right by the fuel T is a little ragged and separating from the metal.
[IMG]
[/IMG]
On to the float height, I'm not clear on the process even though I read some posts about it. Plastic floats are set at 23mm which = .905 inches. I turned the carbs upside down and put the new gaskets on. Then I set my dial calipers at .905 and checked them like this:
[IMG]
[/IMG]
My FSM describes a way different process, jacking up the bike and shimming the center stand to insure the carb bank is level and plumb, let the bike run a few minutes to obtain correct fuel level, and then check the level of each carb with a clear piece of fuel line connected to the bowl drain. The correct level is 3mm +/- 1mm below the "carburetor Mixing chamber body edge."
Are the 2 methods comparable? Which method to use?
The tech tip for Carb Cleaning 101 says to replace the rubber O-rings on the idle mixture screws if they are over 1 yr old. I can't find a part number anywhere for the idle mixture screw ass'y (because the carbs come factory with a plug in the tower?) so where do you buy these?
And finally, the starter jet/choke shaft won't move. It worked fine after I pulled the carbs out of the Pine-sol but I noticed tonight that it's stuck part way open (here's a couple pics). Any idea why?
[IMG]
[/IMG]
[IMG]
[/IMG]
Sorry this is so long, thanks in advance for any help you can give me.
[IMG]
[IMG]
[IMG]
[IMG]
