Trouble adding Brake Fluid to System after Rebuild
  • mmatches1
    • Sep 2012
    • 121
    • Alberta, Canada
    I stripped apart my master cylinder and replaced the parts with a rebuild kit, cleaned the lines and than installed the parts. A while back I removed the disc brakes and replaced the pads. I purchased a vacuum pump from NAPA to draw the fluid through the system. I loosened the bleeding nipple with a tube attached to the vacuum and began drawing fluid through the system. Fluid moves through but mixed with air and the bubbles never bleed out. All along I am adding fluid to the master cylinder keeping the level above the bottom. Am I missing something? Perhaps I am loosening the nipple too much and allowing air to flow in through the thread? The vacuum level on the device says that there is pressure during the process. I have bleed almost an entire bottle of fluid through the system and don't want to try again until I figure this out. Any help would be greatly appreciated. Cheers, Doug
    81H Venture - hope to ride summer 2013
    79F Cafe Racer at Some Point;
    68 CB175 Sloper - Cafe Racer
    74 KZ400 - Restoration project nightmare
    62 BSA Super Rocket - In Pieces
    72 CB100 Super Sport - Not super or sporty but fun
    • 8800
    The air bubbles you are seeing are most likely being sucked thru the threads of the bleeder screw. If you sucked a bunch of fluid thru, you probably got all the air out of the system and I would ignore those bubbles. If you really want to be sure, wrap teflon tape around the threads of the bleeder screw.
      ...wrap teflon tape around the threads of the bleeder screw.
      A big +1 on that. That will not only eliminate the bubbles you're seeing, but make bleeding go faster.
      • snakedriver
        • Feb 2013
        • 33
        • Lansing, Michigan
        I've had this problem too, and I've never thought about teflon tape. Good tip!
        79 F
        • mmatches1
          • Sep 2012
          • 121
          • Alberta, Canada
          Ok - thanks. I tested the lever and the brakes appear to hold firm. However, I noticed than the new pads rub on the discs. Can I assume that the pads will wear down/break in after a short ride?
            A small amount of rubbing can be normal. Yes, you'll need to 'bed' the pads and wear a few high spots off, but as long as the wheel will turn freely it's good.
            • mmatches1
              • Sep 2012
              • 121
              • Alberta, Canada
              It almost sounds like rubber rubbing but I cannot find any tire contact points. The wheel turns but there is good resistance at this point.
                Generally speaking, you won't get more than three turns out the front wheel with everything installed and giving it a good spin. Anything over one turn is usually ok.
                • sthomag
                  • May 2009
                  • 60
                  I've found that greasing the threads works better than tape. I use disk brake grease from Permatex, because it won't contaminate the brake fluid. A generous smear and no bubbles.
                  • mmatches1
                    • Sep 2012
                    • 121
                    • Alberta, Canada
                    Brake grease is a great idea and I will give it a shot. Thanks.
                    • Courtney
                      • 542
                      • Nanaimo BC Canada
                      Well I used teflon tape yesterday and it worked a treat, along with my mightyvac on the rear brake system. Doing the fronts right now!
                      Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
                        Teflon tape won't attract dust/dirt.....
