I recently replaced the cct with an automatic one from a raptor. After replacing it i cleaned the engine so i would be able to see where the oil is coming from if i still had a leak. Well after my first day of riding back and forth from work I noticed oil on the engine up under the carbs so I looked at the CCT and it was perfectly dry but the bolt for the engine that is just outboard and behind the cct was wet with oil.
Here is a picture
So my question is do I have to replace a gasket or can i take the bolt out and gob some sealant on the bolt then reinstall it?
Here is a picture
