can u turn the back rotor
  • Throop25
    • May 2013
    • 46
    • ludingron mi
    so can u turn the back rotor on the 81 special, and does anyone know a good place to find brake pads??
    81 eleven special
    The rotors can't be 'turned', they have to be ground and it generally takes special tooling to do so. There's a few places that can do it, but it will run you about $50 each (that's assuming the rotor isn't below spec on thickness), a good used rotor will be much cheaper. Front and rear are the same, if you have the slotted rotors you'll need the right side...
    Brake pads, do a search to see who's got the best deal this week...
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      Rotor service...
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • ESJr1642
        • Jan 2012
        • 103
        • Groveland, FL
        Disc turning
        There is a place in metro Detroit called Truedisc, maybe worth giving them a call..
        1979 XS110F, Stock
        1980 XS1100G, Mostly Stock, gifted to my son.
        2000 YZ 250, Sold
        2002 YZ125, Sold
        2009 Royal Star Venture
        '94 Pontiac Trans Am, 25th Anniversary, For Sale
        Ernie
        • TomB
          • 967
          • Cumbria, UK
          You lads across the pond have confused me with terminology in the past so I'm going to ask....
          By "turn" do you mean on a lathe?
          I've turned XS1100 discs on my lathe without any problems, if you have access to a lathe do your own, if not go with grinding them, it is easier.
          As to thickness, the discs I run on one of my XS's are well below the manual prescribed minimum thickness and haul up with twin piston calipers so bite hard, but compared to modern discs are still VERY thick, so our yearly vehicle test (MOT) testers are always happy with them.
          Tom
          • FJ111200
            • Oct 2007
            • 317
            • Crewe, Cheshire, UK
            Q: Can you make a u turn?
            A: No, but i can make the bugger's eyes water.
            • MPittma100
              • Aug 2011
              • 2359
              Resurfacing Rotors
              I have a guy near me in Marietta, GA. He can resurface them. Can also custom drill one of several patterns in the rotors if you like. Even repaints the centers. Does good work.
              I can look him up if interested. Just a matter of shipping him yours.
              MP
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
