Guys,
I cant thank you enough for the help so far. I did kind of expect it however when I joined. I belong to a "Yamaha" snowmobile forum and it (and I) have helped hundreds of guys with thier Yamaha's. So thanks again with the help and once I become well educated on the XS1100, I too will help others on this forum.
So...
1- The TCI box for the 1981 was the fix for the lean and running hot problem.
2- I had no idea that the passage from the main jet tube to the pilot jet existed and 2 carbs had this passage way blocked. Now she runs fine and I was able to ride it a little last night. Which brings me to #3........
3- Second gear.... Yep, got it running and of course 2nd gear is slipping. Is the dremel fix the way to go? I have read the threads on the forum and to me it looks like it would work. Your thoughts on the easiest way to fix this?...........Cubby.
So...
