Electrickery
    Electrickery
    I put a digital oil temp guage in later last year and it never read accurately, numbers would vary with rpm some and after 15-20 min of riding it would just max out at 150 C, but if you flip the kill switch the guage drops down to what the temp would really be (90-105C). Sender is located in the back of the oil pan.
    I have a single 12 awg wire in the fairing for a ground for everything in there that runs to the reg/rect or battery don't remember which. Then I have also added a ground from the engine to the engine to the battery. Neither of these help.
    Anyone else have any ideas what is going on here and what might correct it?
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    What are you using for supply voltage? Might try hooking it directly to the battery for supply...and ground, couldn't hurt...
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      Of it was straight to the battery it would always be on. It is hooked to the switched hot wire that is on the headlight bucket.
        Nate, the only thing I can think of is the supply voltage is too high. When you shut off the motor, voltage drops back to just battery voltage and the gauge reads right. Most aftermarket gauges have 'regulators' built-in, yours may have failed. You might try getting a gauge regulator off an older car and inserting it into the gauge power lead.....
          But then if that were the case it would read correct at idle when the voltage is not above 12.5 ish. The oil temp guage is powered off the same line as the volt meter (not through the meter just branched off the same line).
            After thinking about it some more, one other possibility... vibration. I'm pretty sure the sending unit is a bi-metal unit of some sort, maybe the 'frequency' of the XS motor is causing the problem.
            Maybe a different sending unit (with the same ohm range) would fix it, but that's a bit of a guess....
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              I'd measure your supply voltage to various RPM just to see if it varries with the engine speed...
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
                Both volt gauge and oil temp gauge are on the same wire, and I am running a Geezer reg/rect.
                That is a intriguing thought but I don't know why that would be an issue
                  Nate its the time warp effect. What the hell did you expect running a Digital gauge on an Analog bike
                    Little more clarification on the "varies with RPMs" aspect. It isn't like there is any direct corrolation between RPMs and gauge reading, it just has a tendancy to do certain things when I do certain things. For example, if I am high in the rpm range and let off suddenly the gauge will usually drop a few degrees. Could be that the sensor gets uncovered and it really does see a couple degree drop though, I don't know.
                      As a resolution to this thread, it seems that a better input voltage source and/or a better grounding path seem to have solved the problem.
                      Thanks all!
