First off, my Springtime hellos to everyone. I've been dealing with life's other things and haven't spent enough time on or working on my bikes but now that the garage is at a temp I can move easily in, I'm on to working on the remaining bike issues from last year.
I'm needing to replace the fork seals and am going to be using Crazy Steve's excellent tutorial http://www.xs11.com/forum/showthread...ight=fork+seal I am still not sure what to do about the pneumatic connections to the forks other than to discharge any residual air pressure.
I did buy a cheap used triple tree for an XS so I can disassemble the forks a ways off from the bike but my smaller vise is too small to hold them so I'll likely be best to remove everything while the top half is still attached to the triple tree on the bike. That being the case maybe I won't need to remove the pneumatic line between the forks & if that's the case, are there any caveats I should be aware of before removing the bolt on top or something else not mentioned in the tutorial?
Also, since I'll have the springs out, are there any better progressive springs for the XJ11 to replace the stock ones with? If so, which ones in particular? I'm guessing after 30 years of constant tension they may be somewhat less strong than in 1982.
Thanks!
Thanks!
