WTF; new and different first time pilot jet "problem"
  • oldnortonrider
    • 448
    For this carburetor clean and rebuild project (2 racks) ~~ had been "dreading" the extract of the pilot jet(s) ~~ had run the 1st carb through several ultrasonic (8 minute runs) over couple days ~~ blew it clean with good air compress ~~ set the carb and run a medicine dropper of Chem-Dip down onto the jet ~~ let soak for about an hour ~~ and proceeded to put my new jim-dandy-perfect-fit-Snap-On screwdriver to the "test". Came loose and unscrewed just perfect. NOW, it won't fall outta the chamber...........
    JCarltonRiggs
  • mack
    • 2411
    • Ontario, Canada
    Lol
    For the pilot, just take a piece of fine wire and bend a small hook into it. Slip the hook down through the hole and tip to the side and pull the jet out. I house lake fishing line.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      I turn the carb so the jet is facing down, and then put the screwdriver in and turn the jet while lowering the screwdriver.
      • oldnortonrider
        • 448
        ......finally.....success.
        Ran the carb through some more cleaning sessions in ultrasonic cleaner, with the jet being loose in the chamber; let soak overnite. After that, held the carb with chamber hole pointing down, and spun the jet with couple different size mini screwdrivers ~~ trying to drop the jet on down through, and out ~~ no success. Finally, again holding carb with jet hole downward, I started tapping side of carb with small wooden dowel ~~ after a while, the jet just fell and plopped right on out. When I was tapping ~~ could hear the pilot jet rattling around in chamber.........finally, out it came.......amazing................
        JCarltonRiggs
