Engine help
  • Throop25
    • May 2013
    • 46
    • ludingron mi
    Engine help
    so its come to my attention there is a small knock in my engine on my 1981 eleven special, any thoughts on a rebuild or a line on a replacement. were going to do a compression check tommrw.. im not sure if i wanna know the answer this is my first bike and im kinda strapped for cash at the moment, so any advice would be greatly appreciated
    81 eleven special
  • XJkid
    • Jun 2003
    • 281
    • Elk Grove, Ca.
    The valvetrains on these motors are noisy when they are adjusted properly. That is normal. My bike has a small knock too. When the valvetrain is quiet, you need to make adjustments. I also have knocking coming from the crank at idle. I believe this also to be normal. I was racing my buddy the other day, missed a gear, and went up to 9000 rpm. I think if I had a bearing problem, I would have damaged my motor. Others on here have waaay more experience than I. I'm sure if I am mistaken, someone will correct me.
    • mack
      • 2411
      • Ontario, Canada
      Knock
      You'll have to be more specific on the location and sound you hear, when it happens and what makes it worse. Lower front, left side is the advance that can rock back and forth and cause a knocking sound if it's not plugged into the #2 carb properly.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • TADracer
        • 1417
        • Kenner, Louisiana USA
        Another common cause of a 'knock' is slight slack from normal stretching in the Hi-Vo primary chain between the crank and the transmission. The slack will make a noise that can be perceived as a knock at idle but has no ill effects on the motor. Will sound like its coming from the bottom end.
        Mike Giroir
        79 XS-1100 Special
        • Throop25
          • May 2013
          • 46
          • ludingron mi
          thanks guys, this site rocks
          81 eleven special
