I had leaking petcocks on my 79 XS1100 SF. I bought a rebuild kit through http://www.crc2onlinecatalog.com/petcock_rebuild.htm. Everything was going fine until a gust of wind blew my plastic bag of goodies into the grass. I recovered everything except one of the 0-rings that goes around the "cam" or handle control part. I went back with the old one, and it was loose enough to bulge out as I tried to press the handle back in. I managed to get it in, no leaks but that one is very hard to turn now. My questions are:
Do you think this is causing that valve to be hard to turn? and
If this is the problem, does anyone know the part number or even better size description of that o-ring? I would like buy just the o-ring, and not another $30 kit
Thanks!
Thanks!
