Tach testing
  • mack
    • 2411
    • Ontario, Canada
    Could be
    I'm going to clean up the motor side and look very closely at the rotor. There are some filings in there too but for the most part it looks good. I'll check to see if I can find any scores or abraded locations on the rotor itself.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • mack
      • 2411
      • Ontario, Canada
      Coil
      So after cleaning up in there, I found the offending area. It's on the narrow inside sleeve of the rotor which the bolt goes through. Looks like when the coil windings fried the inside lip of the coil wobbled and caused the abrasions. The larger circumfrence of the rotor looks good. The red was from burnt copper, not rust. It blew out with an air gun but lunch won't be tasting too good.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Glad you chose to remove the alt. cover and found the culprit. That would of just got uglier in there with use....
