oops, wrong tire
  • eddielo
    • Mar 2013
    • 35
    • San Jose, CA
    oops, wrong tire
    I ordered the 712s F and R but ended up the front was wrong size. I had ordered 110/90 -19 for the front. WRONG! Should have been 100/90. Yamaha dealer said I had the wrong size so ended up having to buy a Dunlop. They said fender would rub so I had not choice but to get the Dunlop. The rear Shinko was ok.
    Now I have to pay $7 to return for credit even though I am ordering new set for my Yamaha VStar. They're Shinko Tourmasters.
    The size they say will fit is 170 80 15 for the rear and 130 90 16 in the front. But I'm not going by their measurements, from now on I'm going to my bike and get the size off the existing tires. Not ganna take a chance on getting wrong size.
    My Yamaha dealer charges $100 for R&R. Is that reasonable? I think it is.
    2006 Yamaha Morphous "The Space Ship"
    2004 Honda Aero VT750 "Black Beauty"
    2003 Yamaha VStar 650 Classic "primero"
    2000 BMW K1200LT Like new as of 5/10/16
    1999 BMW K1200LT "The Silver Bullet"
    1996 Kawasaki KZ1000P "the 5-0"
    1989 BMW K100RS "White Ghost"
    1986 Honda Goldwing Espencade 1200 (work in progress)
    1982 Honda Goldwing Interstate 1100 (same)
    1980 Yamaha XS1100 fast
    1979 Yamaha XS1100 just as fast
    +6 CTs
    $100 is a bit steep for 2 tires if you bring the rims in, if you being the whole bike then it isn't bad.
    I will say though. A good number of people do put 110/90-19 and don't have problems.
    • eddielo
      • Mar 2013
      • 35
      • San Jose, CA
      No rims. The whole bike. Rims only at Road Rider is $40. So for $60 more I don't have to do anything except drive in and out.
      When I measured the 110/90 it's obvious the fender will not fit. Do I have a narrower fender? The fender looks stock, so have no idea.
      +6 CTs
      • old_skool
        • Nov 2011
        • 554
        • Ohio
        Not sure why you're having a clearance issue, as stated above, a 110 can be used, never heard of anyone not having room under the fender before.
        81 XS1100H
        • ccogswel
          • Jun 2005
          • 302
          • Bowling Green, Ky
          I've stuffed a 110 on other Yamaha motorcycles but never on a xs11. The only thing I had to do was remove the front fender so I could twist the forks to slip the wheel back in. That was it.
          As for the other sizes you listed that they said would fit I have questions. I thought all tire sizes were either in metric or inch's and was all the same. So when they say 170 80 15 for the rear and 130 90 16 in the front! I'm like are you sure? Cause if your paying a fee for a return as it is and you do order these sizes and they are wrong are you gonna have to pay that fee again cause it was their mistake? JAT. And have you checked out http://www.chaparral-racing.com/ They have some good price's on tires.
          Chris
          79 XS1100 Standard aka: Mutt
          Gimme Fuel Gimme Fire!
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            Put the 110 on. I have been using Metzler 110/90V-19 tires for years. Just let the air out of it before you try to slip it up between the fork legs and it will go between the narrow part with a push. No clearance probs after that.
            Mike Giroir
            79 XS-1100 Special
              • 8891
              I have the 110/90 Shinko on my 79 Special, yes it is close to the fender but doesn't rub. Whoever tried installing your front tire didn't try hard enough. They probably looked at the numbers and said this is the wrong tire. Other brands of the 110/90 may be a bit wider and will not fit but the Shinko 712 does.
              Edit: The measurement of a tire empty of air and a tire inflated on a skinny rim will differ, the latter will be narrower.
              • XS1100 Newbie
                • Jun 2009
                • 1106
                • Battle Ground, Washington
                I would be very leary of allowing a dealer to work on my bike. Even r&r on tires can be screwed up, and a dealer can do that easily on these bikes. They obviously don't know what they are talking about with tire size. Factory size tires on my 1980 Special is: front= 100/90-19, rear= 130/90/16. Some folks put a 17" on the rear. Be warned, the dealer is not your friend with these bikes!
                1980 XS1100LG Midnight
                1991 Honda CBR1000F Hurricane
                A cold beer and another one!
                • old_skool
                  • Nov 2011
                  • 554
                  • Ohio
                  Originally posted by XS1100 Newbie
                  I would be very Leary of allowing a dealer to work on my bike. Even r&r on tires can be screwed up, and a dealer can do that easily on these bikes. They obviously don't know what they are talking about with tire size. Factory size tires on my 1980 Special is: front= 100/90-19, rear= 130/90/16. Some folks put a 17" on the rear. Be warned, the dealer is not your friend with these bikes!
                  I agree, most dealers either won't work on older bikes, don't know how to work on older bikes, but if they can't master simple tire installation on any make of bike, they are in the wrong profession for sure. they should try their hand at McDonalds.
                  81 XS1100H
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    Call me a penny pincher or a cheap azz, but to save $60 I'd pull the wheels off myself and take them in to get changed and balanced and desposed of.
                    That way when I put the wheels back on, I know with 100% certainty that EVERYTHING should be where it is and aligned & torqued properly.
                    So what happens when you drive off from the dealer and something doesn't quite "feel" right with the handling/braking? Take it back and have them 'look' at it? NO THANKS.
                    Also, I'm with everyone else here, the 110 should fit. Haven't done it myself, but I haven't heard ANY complaints about it either.
                    I'd hate to ask how much the dealer charged you for that Dunlop.
                    Should have posted up here first and we could have helped you a little bit with this.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                      • 3291
                      I don't see in the initial post that the dealer DID try to mount the tire... I see they SAID it wouldn't fit.
                      edielo, can you clarify that?
                      If they didn't try to mount it, and we know it WILL fit based on no one ever having one NOT fit, you have a fair case to tell them you never should have needed a different tire.
                      The Dunlop (404?) is a more expensive tire than the 712 I suspect as well. Not that the dealer was trying to make a sale, but in their ignorant way of being helpful they didn't listen to the expert on the bike (you) and I would bring it up if it were me.
                      2001 ZRX 1200
                      1982 Seca 750
                      1983 Nighthawk 550
                        Right and wrong
                        I ordered the 712s F and R but ended up the front was wrong size. I had ordered 110/90 -19 for the front. WRONG! Should have been 100/90. Yamaha dealer said I had the wrong size so ended up having to buy a Dunlop. They said fender would rub - - -
                        Hi Eddielo,
                        the dealer was correct in that the XS11 stock front tire size is 100/90-19.
                        The dealer was mistaken when claiming that a 110/90-19 will rub although it's admittedly a real close fit.
                        Many XS11 riders have chosen to go one size up to a 110/90-19 and have ridden them from new to worn out with no problem.
                        Me, I'd change dealers.
                        • Courtney
                          • 542
                          • Nanaimo BC Canada
                          Does the 110 change the odomenter/speedo reading at all? Curious about that.
                          Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
                            • 8891
                            Yes it does, on the Special it actually corrects the otherwise fast reading speedometer but the odometer is now slightly off with less distance recorded, YMMV.
                            • mikubuilder
                              • Jul 2011
                              • 548
                              • Westland, Mich.
                              I learn something everyday...I thought 110 was the width, not height(which would change speedo reading)....
                              Nick
                              1982 Virago 750 (it's alive!)
