Bent valves when following OEM manual rebuild exactly
  • ViperRon
    • Feb 2011
    • 1062
    • Woodstock, VA
    There can be one other pitfall to all this if it is an engine you have never had running. If this is a motor you have not seen run before you take the cams out check the timming and make sure the pointer is in allignment. If the pointer is bent and you take the head appart then your reference point for crankshaft position is skewed. These Valves can be very fragile as I had a friend lay the head on a bench and install the cams to get the shim adjustment close and he bent valves without knowing it. Personally I would not even set the head on a surface resting on raised valves.
    Rodan
    1980 G Silverbird
    1198 Overbore kit
    Grizzly 660 ACCT
    Barnett Clutch Springs
    R1 Clutch Fiber Plates
    122.5 Main Jets
    ACCT Mod
    Mac 4-2 Flare Tips
    Antivibe Bar ends
    Rear trunk add-on
