There is an excellent write up of the procedure here. Investigating the wires won't mess them up if they aren't actually broken already. I found it necessary to remove the timing plate and coils to do repair the wires correctly. Make sure you set the pickup coil gap back when you put it all back together. The four wires eventually go to the 4 pin connector on the TCI. Check each coil for continuity/resistance afterwards. You should see something like 600-800 ohms.
http://www.xs11.com/xs11-info/tech-t...pictorial.html
