Quick electrical question
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    The headlight relay on my 79 special has given up after all these years. The reserve lighting unit gave up last year so I did the RLU removal routine. In order to just ride I jumped two wires at the relay plug so now the headlight goes on and off with the key. I am thinking I might just leave it as is.
    Question is this....Will running the bike with the headlight jumped at the relay plug cause any electrical damage if left like that long term?
    I thought someone recently did a restoration of the headlight relay but I am getting no hits using the search function.
    Thanks
    Mike Giroir
    79 XS-1100 Special
    • 8891
    Mike, I've run both my XS's with no relay for years and everything was fine. One day I took the relays apart and found a wire came loose from it's solder joint. The hardest part was getting the relay open, but yes they should be able to be fixed.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      I've ran with years with my headlight relay jumpered out on my G.
      Just make sure you use a decent gauge wire for that.
      All the headlight amps have to go thru that and it might get a little warm if it's too small a gauge.
      In my case, I think my diode may be bad in the harness.
      The same relay works fine in my SG, so my problem isn't the relay.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        The point of the relay is just to reduce load on the battery when starting the bike.
        • jayel
          • Apr 2012
          • 152
          • Birmingham, Iowa
          one of these will handle just about any headlight you want to throw at it
          headlight Watts/Volt=Amps
          where are we going, and why are we in this hand basket?
          Iowa the Beautiful Land 1980 XS1100SG
          • DAVINCI
            • Jan 2011
            • 1048
            • Cedar Mountain, NC
            Yes, that relay the Jayel posted will work,
            BUT....it's not plug-and-play, it needs 12-14V DC on the coil to operate.
            The original Yamaha relay was designed to work on one phase of the alternator, which only supplies 7-8V AC on a good day.
            SO, I added another diode on another phase and ran them in parallel to the relay, and viola! any standard Bosch automotive relay can be used for the headlight relay.
            Oh, and I might add, if you want to retain the 'hold-in' feature so that the headlight remains on if the engine stalls, you need to backfeed the output pin to the + input pin of the relay coil.
            • TADracer
              • 1417
              Thanks guys, that's the kind of info I needed.
              Mike Giroir
              79 XS-1100 Special
                There is very little current loss through that circuit when compared to the low reisitance of the starter. This is evidence by the dimness of the light when starting. Never had issues with the light ON while starting. I do have two of my 3 xs11s switched and a lighting relay used.
                • dschmitta
                  • Jul 2010
                  • 174
                  • Altoona,PA
                  Been fighting my headlight since small accident in october, e/thing works but the headlight. would love to know how to do this so I can ride. Sorry for jumping on ur post.
                  1980 xs1100g
                    • 8891
                    Headlight Relay Bypass: Unplug unit and connect red/yel and blu/blk together at the harness plug. The unit is under the gas tank just in back of the ignition coils. It has a 4 wire plug.
                    • GLoweVA
                      • Jun 2011
                      • 1957
                      The headlight relay also controls the lights in the gauges, so if they are working, then the relay is working, if so, then your problem is closer to the headlight. Try checking the connections in the bucket.
                      The Green Monster
                      Got him in '04.
                      Scarlet
                      Got her in '11
                      Hugo
                      Cold weather ride
                        The aftermarket lighting relay works by connecting higher capacity wiring on the headlight circuit end, and lower capacity wiring on the switch side. The switch (ie from the handlebar) sends current through the relay, which really is just a solonoid that completes the circuit for the headlight side of the relay. I use a switch on the handlebar from a 1978 sx11 model E, but any switch besides a "momentary switch" will work.
                        • dschmitta
                          • Jul 2010
                          • 174
                          • Altoona,PA
                          Headlight inop
                          all gauges are functioning. When crashed, front fairing was smashed and L/S handlebar was bent right at hi/low switch. Do u think problem could be wiring from bucket back to main pass through harness? Been fighting this awhile. Got factory replacement fairing and h/light still inop, as matter of fact, previous owner had two small fog lights installed in fairing and they are also inop. T/signals work in fairing, just blink opposite of switch position(pushe switch L and R/S blinks and vice versa???) Any help greatly appreciated.
                          1980 xs1100g
                          • CaptonZap
                            • Jun 2010
                            • 1748
                            • Denver
                            Check the wiring connector at the fairing. Dark green is right turn, chocolate is left turn. These are the Yamaha colors. If I remember right, (my 80 is in a distant garage), the color codes of the wires in the fairing are different, but can be seen through the side openings.The wires can be switched in the connector to match up.
                            Bing Vetter, and I think his site has a wiring diagram for the fairings.
                            CZ
                            • dschmitta
                              • Jul 2010
                              • 174
                              • Altoona,PA
                              Will check. Thanks for info. Can't ride till get light and t/signals figured out. State inspection sticker is out and can't get sticker and get on road till lights are done. Thanks again
                              1980 xs1100g
