Some time ago I noticed under WOT the clutch slipped so I finally got around to adjusting it last night at the engine first then at the lever. I loosened the nut, loosened the screw then tightened the screw til I just felt it get resistance, loosened it 1/4 turn, and held it while I tightened the nut.
On the way to work this morning my clutch kept getting harder to pull. Once I got to work I realized shifting became harder. I realized the clutch wasn't fully engaging when I pulled it and that's why shifting was harder( I was basically shifting without pulling the clutch. Once i got off work I tried adjusting the clutch again but it didn't change anything. With the bike off I put the bike in gear, kept the clutch pulled and tried to turn the back wheel but it is hard to turn.
When I try to ride it and release the clutch slowly it doesn't release slowly. the lever some times will be like half way out then all of a sudden the clutch would release to that point then release the rest of the way normally.
I rode it home anyways, and I will be pulling the clutch cover off and maybe even the basket tomorrow.
Also in the last week I have started using Valvoline motorcycle 20w-50 to refill my leaky engine instead of the autozone brand 20w-50 regular oil
Any help would be appreciated as always.
