How does it work when you talk load capacity, and obviously the front tire will take some of the weight? You just add the two load capacities for the total, correct?
I need tires!
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462 -
The OEM rear tire was only rated to 670 lbs, so the Shinko is right there with the stock tire. And if you have a standard with the 17" rear wheel, the Elite isn't even available in that size. The MU90-16 is also an oversize (actually equivalent to a 140/90) so may not fit every bike due to clearance issues with the swingarm.Fast, Cheap, Reliable... Pick any two
With that said, looks like the 712 is right there.
Back to my post #16, I assume the front and rear tire capacities are added together for total load capacity?Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
Not to say having a tire rated higher than needed is a bad thing, it's not. But if you're loading the bike to the point you need the higher rating, you might need a bigger bike...Fast, Cheap, Reliable... Pick any two
Originally posted by hbonserBack to my post #16, I assume the front and rear tire capacities are added together for total load capacity?
My point is not to diss Shinko tires, reviews are generally good, but to give people enough information to make an informed decision. You have to dig to find this stuff; Shinko USA does not include it on their web site and most vendors don't include it either.
You have to make a decision based on your particular circumstance and budget. As I have said, in my case my weight and options (full fairing and saddlebags plus towing a small trailer) I would not buy a Shinko because I would be overloading it even though I am under the XJ's GVWR. The Dunlop makes more sense for me. YMMV.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy StrutComment
Yeah, good points Jerry. Everything you said in the last post points to going with the highest load capacity you can for your bike.
I have an Elite II K491 on the back of my 80SG, wears like iron, great load capacity as you have noted and can't fault the handling in any way.
My 80G came with a good D404 on the rear (3 years old by the date stamp), I put the Shinko 230 Tourmaster up front to replace a tire that was dated over 20 years ago...
I won't be overloading or pushing the GVWR of the bike, so anything that rates as an OEM stock load capacity works well for me.Howard
ZRX1200
I won't be overloading or pushing the GVWR of the bike, so anything that rates as an OEM stock load capacity works well for me.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Yup, lots of margin for CYA built into these tires.Howard
ZRX1200
I installed Shinko Tourmasters on my 79 last year. Wearing much better than the Kenda that was on my XJ1970? Honda Z50... gone
1974 Honda CB200... gone
2008 Honda VTX 1800F
http://www.johnsoldiron.comComment
Really? Interesting. I put Kenda Challengers on and like them, but if the shinko's give better wear, I'll switch to them as prices are similar. Is it Kenda Challengers you have on the XJ?Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.Comment
Real Numbers
I just checked and I've got over 12K miles on my G's Rear Shinko 712. (almost 12 months old, would be less due to me riding the SG for a few months this year)
Now to clarify, ALL but 5% of my driving is interstate and my tire has a good sized bare spot in the middle right now.
Don't worry, I'm planning on replacing it REAL soon.
I even had to put a plug in it 6 months ago. (picked up a nail)
For the price and the periodicity that I have to replace them (about every 9 months due to mileage), I'm gonna stick with these 712's.
MY 2 CENTS!Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
I have Shinko 712s on the XS with 1100 miles and no noticeable wear. The front Kenda I installed on the XJ had noticible wear at 1000 miles. The rear was on the bike when I bought it and appeared to be wearing very quickly. I sold the XJ last fall when I bought my house : (1970? Honda Z50... gone
There is only one Tourmaster, the 230, as far as i know. Really like the way its riding and handling on the front of my refurb'd 80G.Howard
ZRX1200
A little looking around shows a load capacity of 805 lb for the 230 tourmaster in 130/90/16. For not a lot more than the 712 it is a good step up in load capacity.Howard
ZRX1200
