Valve lapping
  • Valve lapping
    At what point should you consider valve lapping? My 11 has 25k miles on it and smokes a little on start up so I have been thinking about replacing the valve seals. Should I look into lapping the valves at the same time?
    Or should I even bother with valve seals at all if there is no other reason to take the head off?
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    If you were truly going to be taking the head off to replace the seals, then YES, I would go ahead and do the lapping. But if you only have a little smoking at startup, but clears once it's running, then like you said, do you really want to tear into it for just a few drops of oil with every cold start!?
      The smoking is from the leaking valve guide seals. Since you have to take the valves out anyway to fix this, one at a time inspect them to see of the contact ring is solid all the way round. If there's a spot that looks broken, then there's a leak there and it would need to be lapped in.
      If there were one leaker, I'd lap them all but otherwise on a 25k engine, you're grinding away material that would be better off left there until this work really needs to be done.
      Make sure each valve goes back in the hole it came out of and be sure to wire brush off all the carbon on the under sides of the valves. You can leave most of the carbon on top of the valve head because it's beneficial (mostly on exhaust valves.)
      Geezer
        if u decide to take the head off
        sit it on its side and fill the ports with fuel
        youll see quick enough if the valves are leaking/seeping.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
          What's your compression ?
          How are the plugs reading, oil fouled or not ?
          A little oil on start up may annoy you with the smoke but if it's not so bad or so long it's lubricating the rings.
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            Everything else is fine. Just the little bit when it starts. I think Ill skip it for now. Sounds like a good winter project.
            Nate
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
              If that's the case, I'd put it off for a couple 3 winters...
              BTW, take it out and run the piss out of it from time to time to burn the oil off the back side of the intake valves. It's fun and good for the bike.
              Geezer
                You mean there's other ways to run it?
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
                  If you ride it like that often I bet the smoke problem clears up a lot.
