Aftermarket Exhaust Systems
  • randy
    • Dec 2003
    • 4521
    I've checked the threads and searched for this, but haven't found it, so here goes. I'm thinking about an aftermarket exhaust and wondered if they come with new header clamps or do you re-use the originals? The originals are on in such a way that I would have to cut the outboard pipe to remove it. The inboard pipe is removable, though. Anyone encountered this issue?
    Randy
  • kf4anm
    • Apr 2003
    • 363
    • Indianapolis
    mac
    i just installed a new mac 4 into 1 on my xj. everything was included except the nuts. it sounds good and doesn't block access to the oils filter or drain plug. my only complaint and its turning into a major one is how low the pipes hang underneath the bike. with mama-son on back i scrape on just about any bump.
    • John
      • 5117
      Whenever Mama-san rides with you, all you need to do is blow up the shocks a little. What pressure are you running in them?
