XS1100SF Grab bar measurments
  • Bish
    • Mar 2013
    • 15
    • Nottingham, NULL, UK
    Hi All , Could anybody with a XS1100SF grab bar please let me know the diameter of the tube & the distance between the shocks & the distance across the rear fender fixings.I am going to have to make one as there as rare as hens teeth.Many thanks Clive . (bish).
    79 SF
    • 2104
    Hi Clive,
    Here's some pics:
    Rear crossbar: (22.03mm)
    Left side:
    Right side:
    Widths:
    A) 295mm (measured installed on the bike, inside to inside)
    B) 282mm (inside to inside)
    C) 261mm (inside to inside)
    D) 182mm (inside to inside)
    E) 227mm (measured just where lower bend starts)
    F) 200mm (measured just where upper bend starts)
    Lengths:
    A to B) from inside of bolt notch at A to slight bend at B 145mm
    B to C) from slight bend at B to vertical bend at C 120mm
    C to where rear vertical bend just starts 120mm
    rear height from bottom of side tubes to the very top of the rear crossbar at center 150mm
    If ya need any more LMK
    HTH
    • Bish
      • Mar 2013
      • 15
      Thanks
      Hi , thank you for the measurments
      79 SF
