oil type question
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Guys ! The 1100 and the 650 use the same clutch, yes ? When I had a oil temp reader on my 650 during a 450 mile run over the Wild Cat Mountain during a rally back in 04 my temp went up to 275F. I called the run to a stop ( bad thing)
    until I cooled down a bit, it was close to 100F outside. Next time I put in Tony Hall's suggestion of a cup of Slick 50 lube and Micheal Mercury Morse's recommendation of using 1/2 qt. less oil in the 650. I always use Yama Lube but now in the 650 and the 1100LH, 1 cup of Dura Lube. No problems with clutch slipping and very nice shifting on the 650 much better on the 1100. Dura Lube or Pro long is a smaller cell size that is better suited to the filter on the 1100, does not matter on the 650 screened filter. JMHO from testing.
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      snake oil
      I wouldn't put any of that "snake oil" in my bike. Especialy anything with tefflon or other stuff, your clutch is in that oil. These are not worn out car motors that "MIGHT" slow an oil leak, or seal a gasket with some "snake oil", just IMHO, good luck with your bike
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        Originally posted by Janzellotti
        ........ Bare with me as I have. ADHD And sometimes I get confused or forget things
        Hi Jason,
        make yourself a startup checklist.
        Stamp it on as small a piece of aluminum sheet as it will fit
        or use a label maker and stick the labels on a piece of plastic.
        Keyring it to your ignition key.
        It should say:-
        ignition ON
        gas ON
        killswitch ON
        choke ON
        trans in NEUTRAL
        sidestand UP
        Most likely you'll only need it for a short while, until the procedure burns itself into your mind.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Hi Jason,
          It should say:-
          ignition ON
          gas ON
          killswitch ON
          choke ON
          trans in NEUTRAL
          sidestand UP
          +1, it is so simple, key, gas (choke or not) start, ride
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            • 2096
            Hi Jason,
            It should say:-
            ignition ON
            gas ON
            killswitch ON
            choke ON
            trans in NEUTRAL
            sidestand UP
            Great tip Fred
            This thread was getting so far off track it was almost spoiled.
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              I read the title of this thread and thought to myself, oh boy another oil thread...
              Then I read his post about turning the petcocks to prime and vrooom, whereas before he was turning them to 'on' and it wouldn't start.
              With the the standard petcocks if the fuel lines weren't completely full then there would be a delay in getting the fuel to the carbs until the vacuum petcocks allowed flow after several cranks. But on prime there was no delay and VROOOM.
              Oh, +1 on the temps in FLA.
              Even here in VA in the mornings it gets to about 35-45F and my G has no problem starting with full choke on the 2nd or 3rd crank. (with the 20/50 oil and an oil cooler!)
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
                • 8061
                +1, not oil problem. In my personal experience, the seat of my pants can not tell the difference between 15W40 and 20W50. Also, I have used plenty of synthetic motor oil without issue. I must point out that all of the synthetic oil I have run has been the motorcycle specific variety. As stated, avoid the "ENERGY CONSERVING" label.
                Are the choke passages in the float bowls clear? Does it start with the choke open and the throttle closed? That beast should start, even if well below freezing.
                I would make sure the battery is alive and well. A strong battery should have no trouble with a Florida winter.
                Remove the float bowls. Spray carburetor cleaner into the choke passage on each and make sure it passes through.
                The image isn't an XS11 carb, but it's close enough to get the job done.
                • GLoweVA
                  • Jun 2011
                  • 1957
                  [QUOTE=jetmechmarty;404735Remove the float bowls. Spray carburetor cleaner into the choke passage on each and make sure it passes through.
                  [/QUOTE]
                  Just make sure you've got eye protection!! DAMHIK, BTDT! That cleaner will come shooting right back at you!
                  The Green Monster
                  Got him in '04.
                  Scarlet
                  Got her in '11
                  Hugo
                  Cold weather ride
                  • donebysunday
                    • Oct 2012
                    • 1737
                    • New Berlin, Wi.
                    Holding that float bowl in the right direction when shooting carb cleaner into that choke passage is important, as the cleaner will also sting your skin and melt little spots on your safety glasses.
                    Think what absorbing it through your skin and into your blood might do.
                    Good point ! With four carbs and maybe one or two choke passages plugged it would most likely still start under perfect conditions ?
                    76 XS650 C ROADSTER
                    80 XS 1100 SG
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      Oil
                      Not to start the "Aw, Jezz, not this s#!t again" oil post, but I will add, when I changed from 20w50 to 20w40 (not for cold reasons) my bike shifts better asn runs quiter, JAT, YOUR RESULTS MAY VERY
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                        • 2096
                        Exactly, I really think the 50w is too thick for these Russian Trannies
                          • 8061
                          There's no such thing as Yamalube 20W40 motorcycle oil any more. I've been buying the 20W50 in bulk because it's cheap. I've also used 20W50 off the shelf at the parts store, 15W40 Rotella, synthetic motorcycle oil in 20W50 and 10W40. I can't tell the difference with any of them. I avoid the "ENERGY CONSERVING" label. Otherwise, as long as it's clean and slippery, it works fine for me.
                          Clean up those choke passages and tell us how it works!
                          • Janzellotti
                            • Mar 2013
                            • 39
                            • central florida
                            All has been good gpt new battery and started in the morning with frost on windshields . got my bike checkout all is good now .lovin the clubmans flipped low didn't go with the tracy fairing thanks fellas for all the help
                            79 Kenny Roberts Tribute
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              Search the world's information, including webpages, images, videos and more. Google has many special features to help you find exactly what you're looking for.
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
                                • 8061
                                On the Yamaha site, the 20W40 is outboard engine oil. I don't see 20W40 motorcycle oil.
