Hi everyone, It has been a while since I have posted, although I still continue to monitor things pretty frequently.  I have had my 78 xs 1100 out several times this year, but now I have a recurring problem that developed at the end of last year.  (I guess that I thought it would fix itself over the winter.)
When I grab the front brake lever there is signifcant play. The adjustment bolt is all the way out, it just takes it a while to get to the piston. It is as if the piston does not come all the way back out of the master cylinder. Sometimes the brakes work fine and sometimes I have this problem. When the lever does meet the piston, there is enough force to stop the bike, but not like before.
I have bled the brakes, and last year cleaned out the "spooge hole" very well. A couple of thoughts enter my mind.
1. When I put new brake fluid in, did I not bleed enough? (i did not see any air coming out, only fluid.)
2. Does the spooge hole need to be re-cleaned?
3. Is the piston sticking on the inside? Why would that start at the end of last riding season when it worked great for 2 years?
4. Should I just sell this bike and get a VTX 1800? (I like not having a payment)
Thanks for any help that you all can give me,
Travis
P.S. I do have stainless brake lines.
Travis
