Need new carbs??
  • cclark1788
    • Mar 2013
    • 5
    • Des Moines, Iowa
    Need new carbs??
    i bought my bike last year and have done a lot of work to it but I can't get the carbs set right. When I got the bike all 4 pilot screws were broke off and being new to this, I listened to a guy and just drill them out. Now the holes are too big. I think they got drilled out to 1/16". I've messed with them a lot since then trying to get them set but no matter what I do all you smell is gas when its running. I'm pretty sure I ruined them. Now i'm just looking for a good set of used carbs I can rebuild the right way without spending $500. I cant seem to find any anywhere. Do you guys think I can reuse these or if not where I can get a used set? Whatever help would be appreciated. Thanks.
    79 SF
    Do the screws still bottom out, seal off? Of course, go very lightly when seating them so as not to get them stuck again. But they will probably be more finicky than the stock hole size to get set correctly, much less movement to get the same result.
    • Diskman01
      • Mar 2011
      • 263
      • Sioux Falls, SD
      I wish people would tell folks HOW to drill out the pilot screws PROPERLY..
      I used a 1/16 bit with masking tape wrapped around the edge. Leaving the tip exposed about 1/8 inch.
      What you are actually doing is NOT drilling out the tiny hole..
      You are simply removing small amounts of the broken needle tip from the inside, THEN trying to force it out with a pushpin from the air side.
      Repeat in SMALL steps until you remove just enough material in the inside to pop out the broken needle.
      I also drilled my #4 carb completely through as that's what I thought people meant. When my #2 snapped, I did the new way. I still have a factory air-hole in #2. My pooched #4 requires a "special" mixture screw with a very short spring and a large rounded tip.
      Sorry about your carbs. Depending on how big the holes are, maybe you can ask others for THEIR broken mixture screws and use short springs like I did. It does make tuning a bit funky, BUT it does work.
      At least till I win the lottery and can afford new carbys.
      1) Fire up Internet Explorer
      2) http://www.yahoo.com
      3) type "www.mapquest.com" into the Yahoo search page.
      4) go about day as VP managing multi-million dollar financial contracts.
        • 8898
        +1, I just shortened my springs and let the tips protrude further down into the carb throat, you may need to grind the tip some as needed. It helps if you have a colortune plug to see what is actually going on with the combustion color. Clark, are you sure you have the correct pilot jets with 6 air bleed holes in the sides? There are others that fit but will produce an overly rich mixture as you are describing, JAT.
        • cclark1788
          • Mar 2013
          • 5
          • Des Moines, Iowa
          I dont think i can seat them. I think the sping compresses before they seat properly
          79 SF
          • cclark1788
            • Mar 2013
            • 5
            • Des Moines, Iowa
            Too bad i didn't know how to properly remove them then. The guy told me to drill all the way through so thats what i did. Could i just cut some off the orignal spring or i do i need to get another spring?
            79 SF
            • cclark1788
              • Mar 2013
              • 5
              • Des Moines, Iowa
              I'm not sure what they are. I bought the bike and the previous owner said it was all orginal. He was going to restore it but lost intrest. I can get it to idle but it idles high. When i ride with my buddys they say they can smell gas bad behind me. It has the 4 into 1 exhaust and i took the baffle out and put a k & N filter in it. It doesn't run any better with the baffle in. I had it synced the best i could with the gauges and at WOT (about 6000RPM's it sputters perty bad). It also doesn't have the octopus on it anymore. The fuel lines run straight to the carbs. I want to get a set of 2 into 1's for it because the 4 into 1 hangs too low i think but i need to figure out this carb situation first.
              79 SF
                Tuning the carbs and then changing exhaust is doubling up on your work. You will need to retune and possibly...maybe..rejet for the 4-2 instead of 4-1 change. Especially if the 4-2 has decent baffling and your 4-1 does not as you indicated.
                I would recommend adding in line fuel filters. A lot of folks run without the OCTY valve.
                Generally speaking, these engines like/need some back pressure in the exhaust. So the alck of any baffling will make it a b!tch to tune.
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  For a permanent fix, you could drill them out slightly larger with a drill press to ensure the holes are straight. Then find a small jet with the same size head as the hole, cut the threads off the jet, and press it in. It's only a piece of metal.
                  • scalded dog
                    • 458
                    I have an '80 set of good carbs, but not sure if you can rejet them for the '79, maybe someone has experience in this...Later 'Dog
                      Carbs are jetted according to the year of the carbs, not the year of the bike.
                      • cclark1788
                        • Mar 2013
                        • 5
                        • Des Moines, Iowa
                        If i cant get mine to work i will be needing some if you'd be willing to sell. What would you have to have out of them and what would it cost to ship them to zip code 50220?
                        79 SF
                        • scalded dog
                          • 458
                          They are off a running bike, cleaned real well when I was trying to get this '80 special running right, but motor is toast, so am parting out, will take $125., plus shipping, will check shipping prices if you want to buy, the carbs...Later 'Dog
                            Hi Cody,
                            I drilled out one of 3 carbs on an XS750 with a 1/16" drill bit because my drill chuck wouldn't grip the correct (1mm) size and it ran kinda OK after.
                            Try grinding the springs shorter. It's easy to do, it might even work and it's a zero-cost option.
                            Or make a deal with scalded dog, the '80 carb rack will drop straight on.
                            • Yard Dogg
                              • Mar 2010
                              • 884
                              • Tri-Cities, Wa
                              I wasn't talking about re-jetting. I just meant that you could re-drill, and press a jet into the pilot hole to recreate the small hole that was drilled out. Then you pilot needle would have a better seat. FYI
