Air Filter
  • captjanes
    • Jun 2012
    • 72
    • Newfoundland, Canada
    Air Filter
    i was thinking about removing my air box and installing indvidual air filters directly to my carbs but what do i do with the crank case vent tube that comes up and goes into my air box??? can i just remove and plug that tube or do i need it for venting/lubrication?? heres a ebay link of the filters.
    1980 Yamaha XS1100LG Midnight Special
    As for the vent, just leave it open. DO NOT PLUG IT, HAS TO BREATH! You could put a small filter on it to keep critters out of your crankcase when the bike sits.
    On the POD air filters, watch for the EMGO I believe it is, they have a lip on them that will partially block the openings in the inlet bell of the carb.
    • captjanes
      • Jun 2012
      • 72
      do you have any idea where i can buy a small vent filter for this tube?? maybe a filter where i can install right on the casing and get rid of the pipe
      • captjanes
        • Jun 2012
        • 72
        im thinking a filter like this will work?? it has a 3/8" nipple so that should work on my vent tube
        http://www.ebay.com/itm/crankcase-ai...c98719&vxp=mtr
        • Tat2demon
          • Jun 2012
          • 718
          • Sioux Falls, South Dakota
          When I bought mine the PO had used an automotive valve cover breather on the crank case. They used a rubber adapter so it would fit. I can get a pick of the adapter later for you if you would like.
          Nate
          78 XS11 "Matilda" 2H7 000364
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
          • captjanes
            • Jun 2012
            • 72
            pics would be great thanks
