Help! VMax Autotensioner Leaking
  • BigOates
    • Mar 2013
    • 71
    • Montgomery, Al.
    I picked up my first xs11 a week ago. Since then I've replaced the cam chain, cleaned the carbs (waiting on my color tune to come in the mail), and done a ton of other maintenance on it to get it ready to ride. The adjustment bolts on the stock adjuster were stripped so I decided to replace it with a vmax Autoadjuster I picked up off of eBay. It was off an 86 vmax if that matters. Anyways, after replacing the cam chain and buttoning everything up yesterday I started it up and noticed a steady stream of engine oil coming out of the bottom bolt hole of the cct. I did a search on here and found the bolts needed to be shortened due to the vmax tensioner being thinner than the stock unit. I placed a few washers on both bolts and it seemed to take it from a steady stream to a steady drip. I'm stumped at this point as to how to proceed. Anyone have any other ideas or been through this before?
    Jason
    Montgomery, AL
    80 XS1100SG Daily Driver
    81 XS1100SH (Getting ready for an engine rebuild)
    86 Honda Magna V45 (sold)
    The stock bolts are about 1/8" too long, so a 'few' washers may not be enough. I'd pull it, shorten the bolts and re-seal it...
      I suppose this is linked to the V-Max and not the Venture tensioners. I have always used the same bolt as the stock unit and never had any problems.
      Did you use a paper gasket for the seal? I have been using black RTV and it has not leaked a drop. It may be forgiving of that gap, but I would think an 1/8" would still be a lot of gap for it to seal.
        Is it possible that you cranked down on those bolts until the casting broke? There are a lot of folks who think tighter is always better, and it's through inexperience. It's fine to shorten the bolts with washers.
          Both the Venture and V-Max tensioners are the same and it does require shortening the bolts a bit. Those ARE 'bottom' holes. I used the allen bolts that came off the Venturer adjuster. Also, had one bike I had helped change, and it had a similar problem. Found the head casting had a burr around it keeping the adjuster base from pulling up tight, even though bolts seemed to pull up tight. Something you may wanna check, as I have seen this on two occassions now.
          • BigOates
            • Mar 2013
            • 71
            • Montgomery, Al.
            Well I pulled it back off and made sure I had just over 1/8" worth of washers on each bolt then used some Hondabond gasket maker to seal it. I didn't see any burrs and the casting looked good from what I could tell. I'll test it out tomorrow and see how it does. The stripped out casting could be a possibility, especially since the original tensioner was leaking from the same area when I first got it from the po.
            Jason
            Montgomery, AL
            • BigOates
              • Mar 2013
              • 71
              • Montgomery, Al.
              Just wanted to say thanks for the help. The addition of enough washers to take up just over 1/8" solved the problem. Now as soon as my dynojet kit gets here I'll hopefully have her on the road.
              Jason
              Montgomery, AL
