Simplified wiring
  • spayne83
    • Jan 2013
    • 159
    • Campbell, CA.
    Simplified wiring
    I am trying to remove all of the parts of the electrical system that I don't need, but the wiring diagram is hard to decipher especially without knowing what black magic happens inside those relays.
    So I am trying to remove the Light Checker Unit, the Flasher Cancelling Unit and the Reserve Lighting Unit. I'm following the tech tip for the RLU, but there is not much that I can find as far as actually removing the LCU and the FCU.
    Light Checker Unit:
    From what I can see, the oil/brake light gets power from the green wire at the RLU and the rear Tail Light gets power at the LCU from the L/Y wire from the main switch. So from my thinking I should be able to jumper the L and the L/Y at the LCU and potentially even tie in the G wire from the RLU, because that is power when the main switch is turned on.
    Flasher Cancelling Unit:
    The R/Y wire gives ground to the unit when the flashers are turned on (the turn signal connections box show it connected to ground when the flashers are on). The G/Y wire gives power to the flasher realy which passes that to the Br/W wire which supplies that power to the Chocolate and Green wires depending on which flasher is on. Then the G/W is to the reed switch which shuts off the blinkers after a certain amt of distance. So what I am thinking is that I can cut off all those wires and just go to a two prong flasher relay.
    I just want to make sure that I am reading this correctly before I go hacking at my wiring harness again.
    79 SF 3H3 Engine, 145/45 Mikuni Jets, El Cheapo Pod Filter Mod w/ EMGO Pods, Coil Repower w/ Dyna Coils, Accell Wires and Side Gapped Plugs, 78 Mech Advance, 4-2 Turnouts
    Originally posted by spayne83
    Light Checker Unit:
    Tie the blue/yellow and blue at the checker together for the taillight, you can ignore the rest. For the canceller unit, just unplug it; the turns will work without it. Simply install a 2-prong flasher (or you can leave the stock one in place if it's good).
    As far as hacking the harness, I wouldn't. Any weight saving will be about zero (a matter of ounces), and if you ever want to return to stock, the wires will be there....
