I've put the bike back together, but still no start.
So following the TCI repair thread (http://www.xs11.com/forum/showthread...t+spark&page=3), I checked the voltage at the TCI and on the R/W wire I get a steady 12.5V with the ignition on. At the R/Y wire I get 11-10.5V (never less than 10.5) when cranking. Between the B and Orange wires I get .53V when I turn the switch to run and also when cranking and it quickly drops to 0. Same with the B and Gray wires. The resistance between Gray and Orange Wires is 6 ohms measured at the connection to the coils. I used a spark checker and the coils are not firing on either #1 nor #2 so I would assume there is no spark on 3 and 4 either.
Brand new coils, and wires, and I checked the connections at the TCI and used DeOxit on all of them. I also sweated all of the connections on the TCI board. I can't figure out why I am not getting the 10-11V at the gray and orange connectors. Does that mean that my TCI is bad?
