rust and the exhaust
  • Nightengale
    • Jun 2011
    • 521
    • Hampton, VA.
    Does anyone know the best method to remove rust from the inside of the exhaust system?
    xs1100 hartail bobber
    http://i1169.photobucket.com/albums/...-38-36_563.jpg
    • 5061
    Not really, but I am thinking of the reason the rust is in there. Do you tend to take short rides and shut the bike down before it reaches normal running temperature for a period of time? Combustion water ruins exhaust systems in bikes, and cars, for that reason.
    • red bandit
      • 951
      • central michigan
      How much rust are you talking about. A little surface rust or big scally chucks? A little surface rust I wouldn't worry about.
      79 SF parts bike.
      • Nightengale
        • Jun 2011
        • 521
        • Hampton, VA.
        sittin off a bike for some time
        its for some headers and exhaust, i found that a friend of mine has that i was thinking of trying to see if i could make a custom exhaust for my bike. they were off the bike and in a shed and had been out there for some time and when i picked them up you could hear the rust shakin around, and when i turned them over some rust fell out of them.
          I used Metal Rescue on a somewhat rusted gas tank and it did a great job cleaning it up. You could seal one end of the pipes and pour it in the other and seal it to let it work its magic.
          • Nightengale
            • Jun 2011
            • 521
            • Hampton, VA.
            ill try it
            i was thinking that would work think i will give it a try.
              The only problem will be seeing inside enough to know when it is finished working. I'd say give it 12 hours or so if it is really bad.
