I have a shake in the fork at 80 mph.
82 xj purchased in Nov 2003. Had the original back tire at 15,000 miles and previous owner self mounted a cheng shin backwards on the front. Replaced the rear with michelin commander. I think when I first took the bike on the interstate it smoothed right to 80 with no problem, I know it did at at 5K rpm. I replaced the yamaha fairing with a vetter five and lowers. But now at 80 the instruments shake real bad and looking down the forks they move front to back what looks to be about an inch. I had the front tire turned around and balanced, very small weight, no change. Had the shop check over the front end. They thought the steering might be a little tight, it doesen't flop from side to side, but found no problem. So I replaced the front tire with the matching michelin commander. Allowing about 50 miles to seat the tire, it still has the shake, maybe only slightly less. I have tried different damper settings and several presssure settings.
Surely this can be corrected. Where do I start.
Guy
Guy
