Carb help
  • Aches n Pains
    • 349
    • Reston, Va.
    Carb help
    Guys,
    I'm working to resurrect a 1978 E (http://www.xs11.com/forum/showthread...833#post402833).
    I have a really nice spare set of carbs for my '79 Special and was wondering if they are just plug and play for the E. In the Clymer manual (p. 145) it would appear that the only differences are the model number and the pilot jet (40 in the E and 32.5 in the SF).
    How would they perform if I just mounted them? If I swapped out the pilot jets?
    As always, thanks for your help.
    Doug (Aches n Pains)
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    It's the starter jet that's different, and that's not replaceable in any case. So yes, no problems with swapping and rejetting won't be needed (unless you've changed other things like pods or aftermarket exhaust).
      They should be fine, make sure they are internally clean and toss them on.
      • Aches n Pains
        • 349
        • Reston, Va.
        Thanks. They are all cleaned and polished.
        1995 KZ100P
          Hope you have checked your float levels, should be 1" with brass floats.
          Edit: Plastic floats; 29/32"
          Both are with carbs upside down, from bowl gasket surface, gasket removed, to highest part of float bulb.
