Worst wrenching experience
  • Yard Dogg
    • Mar 2010
    • 884
    • Tri-Cities, Wa
    Those blown up gas tanks can make a real nice café headlight fairing and rear fender.
      • 5057
      It is hanging on my garage wall like a trophy tuna fish!
      • ViperRon
        • Feb 2011
        • 1062
        • Woodstock, VA
        None of the above apply to me but after having my company van serviced in a Ford dealership I had to take off in a snow storm. In the middle of nowhere low on gas no phone I had a flat. One by one all the studs snapped off trying to take the wheel off because they had been over torqued . That last snap put a sense of fear in me.
        Rodan
        1980 G Silverbird
        1198 Overbore kit
        Grizzly 660 ACCT
        Barnett Clutch Springs
        R1 Clutch Fiber Plates
        122.5 Main Jets
        ACCT Mod
        Mac 4-2 Flare Tips
        Antivibe Bar ends
        Rear trunk add-on
          • 5057
          #34
          LoHo! Eighty-tighty lefty-loosey. 8-)
            • 5057
            #35
            Stupid autocorrect function. You know what I meant...
              Originally posted by edgo
              alternator change, Ford Escape.
              ........being it's a Yamaha motor would be the good part.....
                • 9980
                Escape has a Mazda engine.
                • barrelguy
                  • 169
                  • Oliver, BC
                  #38
                  Third time smart
                  Tightening a fan belt on girlfriend's Volvo:
                  1st Use ratchet handle to provide tension. Slips. Smash end of finger on bolt.
                  Much colourful language.
                  2nd Try again. Smash same end of finger on same bolt. Much more colourful
                  language, accompanied with much jumping around.
                  3rd Go to garage to get appropriate pry bar. Much quieter.
                  1980 XS 1100 Special
                  Mostly stock & original
                  Added Yamaha fairing (w/ 8-track!)
                  Torpedo bags
                  New paint (still) pending
                  Stainless brake lines
                  Tkat forkbrace
                  Coils from Honda 1000
                  Previous bikes:
                  1968(?) 350 Harley Davidson
                  1977 Yamaha 650
                  • Rasputin
                    • 3187
                    • Lacombe, Alberta, Canada
                    #39
                    I decided one night to let my oil drain on a Ford 289 in a 66 Fairlane while I went in and had supper. The motor had less than 100 miles on it and I had spent about 2700 bucks on all the pretty parts. This was a lot of years ago, basically when the first roller cams came out.
                    My buddy came over and I said I would be done in a few minutes and to hang tough till I finished supper and I would add the oil and we would start it up.
                    Dumbass went out and poured 4 quarts of oil in and decided to start it up while I was still eating.
                    You have no idea of how fast you can run until something like this happens!!!
                    All the oil he added was drained into the drain pan under the motor as the oil plug was sitting on the fender well the whole time. I was one unhappy dude.
                    Still makes me sick thinking about that brand new motor with all the money I spent only lasting 2000 miles.
                    2-79 XS1100 SF
                    2-78 XS1100 E Best bike Ever
                    • Yard Dogg
                      • Mar 2010
                      • 884
                      • Tri-Cities, Wa
                      #40
                      That's cause for an azz woopin. My most memorable moment was this time in high school when I built a Volkswagen Rabbit. I was working a crappy part time job and had moved in with my dad which was 25 miles away from school so I was pressed for time to finish my motor during spring break. I rebuilt the entire engine in a few days. I installed a Porsche 944 head, a huge pinto carb and performance cam. The mistake was made wen received pistons which were supposed to be pressed pin, except they didn't press, just slid in and out. Being in a hurry, my dad got the bright idea to cut grooves into the pins so we could use circlips. We got the motor together an it ran for about 2 weeks. This MF would do 60 miles an hour in 2nd gear and I as eating up Camaro Berlinettas, Hondas, and everything I could. One morning I was late for school so I ate up the freeway at 120 miles an hour. It was a 4 speed so it was probably turning 8 - 9K RPM. All of a sudden the cab filled up with smoke and I smoked out all 4 lanes on the freeway. That thing blew sky high when the piston keeper came out and shredded the block. It was awesome, of course I was upset.
                      • Phoenix Rider
                        • 460
                        • Port Perry, Ontario, Canada
                        #41
                        I think the worst sinking feeling I have ever had with my XS was when I was removing the exhaust that had been on there forever. It went from being tight to, oh there it goes, to the bolt snapping off in the head. Then to make matters worse was me drilling out the bolt and having the easy out snap off inside. Out of all the things I have had happen, that had to be the worst.
                        Wayne
                        80 XS1100 SG "Phoenix"
                        "We are the type of band that if we moved in next door to you...Your lawn would die"
                        Lemmy from Motorhead
                          Worst wrenching experience for me? Using my time, tools, spare parts, and fuel to help someone get their bike going, only to have them turn around and sell the bike.
                            #43
                            Fred that is some serious redneck engineering!
                            John
                            Hi John,
                            that's when the need to ride trumps decades of engineering training and experience.
                            What IS a great idea is putting a triprail on the front edge of a workbench to stop things rolling off it.
                            Shoulda done it sooner.
                            • Prothec
                              • Jul 2007
                              • 587
                              • Fort Myers, FL
                              #44
                              I hate that. Last summer I helped a coworker with a GSXR600 wiring and carbs only to have him sell it right away for a loss to get some quick cash.
                              Website/Blog
                                • 9980
                                LOL......bike-b-q
