Painting horns
    • 3192
    Painting horns
    What advice do you guys have on prepping/cleaning the horns for paint? I have an 81LH with the dual horns that are kind of hard to find so I do not want to damage them before or during painting. I do not want to spray something like brakekleen on them and find I screwed them up. Any tips or previous experience with this?
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    Howdy Ras,
    The ones I dealt with were off the 80G, so I don't know if they changed in 81. If they didn't the horns can be disassembled and painted piece meal. Actually you can mask off the outer face ring and terminal, and paint the body. There is a screw and lock nut on the back side that is used to "tune them" after you get them back together.
    The chrome plate in the center can be removed, paying attention to the washer sequence, and taken to a buffing wheel, or cleaned by hand. The chrome ring that is riveted around the periphery can be cleaned in place, or the rivets can be removed, the ring buffed clean, and replaced with small bolts on re-assembly. If they are not removed, the assembly can be cleaned with solvent, carb spray, etc, since the diaphragm is sealed by the outer ring and rivets. I think there is a vent hole on the back side, so I wouldn't immerse the horns in solvent.
    Since the faces of the horns are subjected to stone damage, the chrome tends to rust in the dings, and must be attended to frequently to maintain any semblance of shiny.
    The internal working are a simple vibrator with points, and if the horns don't work, and there is electrical continuity through the two terminals, they can sometimes be resurrected by getting inside (removing the rivets) and cleaning the contacts.
    They are pretty robust, so don't be to worried about working on them.
    Glad your feeling better.
    CZ
    • jwhughes3
      • 2798
      • Home of the Alamo
      Here I was all excited as I thought you were gonna paint Longhorns on your bike!
      Glad you brought up the subject as I have a set of dual horns that needed repaint.
      John
      '81 XS1100H - "Enterprise"
