Does anyone know what temperature the exhaust pipes coming out of the head should be?
I measured mine on the first downward curve using a laser thermal gage. My #1 & #4 are running around 325 and #2 & #3 are at 265.
I swapped coils and ignition module with no change. I have been going through this bike for a year and just was able to ride it Sunday when I checked and found this issue.
I have the same emulsion tubes and jets in all four carbs.
I also thought about the valve clearances and may have to check them one more time. The shims were changed a few months ago. I did a thread on this because I tried to swap a shim from one place to another and found that you shouldn't rotate the motor without a shim in the bucket. So maybe even though the correct shim was put in, the buggered up cam has changed the actual required need.
Before I go back into the valves I plan on enriching the 1&4 a small amount to see if those will cool down....
It is running the best that I have seen at this time. It might be best to ride and not worry about it?
What temps do you see?
