Mikuni BS36 CV carbs for XS1100
  • McShafty
    • Jul 2012
    • 31
    • Melfort, Saskatchewan, Canada
    has anyone tried this conversion? i found a bit on them in the assie forums. they mentioned running 140 jets. but talking to the a supplier they have never heard of needing such a large jet.
    81 MNS
    • 5050
    I have bigger ones in my 78E with a Jardine 4 into 1 header and K&N individual air filters. It is still too lean at WOT.
    • TomB
      • 967
      • Cumbria, UK
      I use BS36 MKIII Mikunis, you have to use a much bigger main jet because air flow velocity is slower on a bigger choke size when used on our bikes (the carb bore, not the thing that helps it start when cold), the bigger choke size causes slower air speed and therefore less venturi effect on the needle jet causing weak mixture. I have fitted CB750 carbs to a CB77 and had the same issues
      On standard XS1100 early carbs, the MKII BS34's, 132 mains are fitted, I have used those in my MKIII BS36's but still need to up a few sizes, so 140 sounds about right.
      Your supplier may be referring to standard use of these carbs when saying he's never heard of needing jets that big.
      My BS36's came from an FJ1200, I also have a set from a XJR1200, doubt you'll get those over your side though
      Tom
      • LoHo
        • Sep 2002
        • 1341
        • Fresno, CA
        Skids, with large jets and wide-open air flow, what sort of MPG do you see?
          • 5050
          Ooodles of low end torque (fun), about 38mpg city and 32 highway. This is at one mile high.
          • McShafty
            • Jul 2012
            • 31
            ok ill give the 140s a shot. my experince with carb mods is limited so bear with me lol
            81 MNS
              • 5050
              I should have also told you that these were the original style carbs.
              • XrockerS
                • Oct 2013
                • 20
                • San Diego, Ca.
                This sounds like what I wanted to read! Tom B I have a set of BS36 on my Xs nd i'm wondering what would be a good place to set the floats at? do you remember what yours were set at? I haven't checked my jet sizes but I will soon. another thing I was wondering is what are you doing to accommodate the vacuum advance?
                Marc Garcia
                Simplified wiring
                DynaTek green coils 3.0 Ohms
                High performance spark plug wires
                Blade fuses
                Motoscope Mini Digital speedometer
                R6 start button
                Zx6 left controls
                Mikuni BS36 Carbs (Gold tops)
                Mikes XS tapered pod filters
                4-1 headers w/open exhaust
                Tkats fork brace
                previous toys
                1981 XJ650
                1979 KZ650
                1978 CB750
                1971 CL350
                2008 VZ800
