Fast idle...
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Fast idle...
    I have her back together, the carbs are synched, she leaks oil from a couple of new places, and another issue has come up (yeah, I'm shocked, too).
    The master idle adjuster is opened all the way, no longer in contact with the throttle, and the idle hangs around 1900rpm when warm and no choke.
    Changes from when she ran: new head gasket, new #3 intake valve, carb floats adjusted to spec (she ran fine for years with the floats set very high/rich), idle screws 1.5 out, Iridium plugs, numerous curse words and violent oaths.
    I am willing to bet that your throttle cable is hung up somewhere or it is not properly seated in the little hold notch on the top side of the carbs.
    • LoHo
      • Sep 2002
      • 1342
      • Fresno, CA
      I thought of that, but no dice...there's even a bit of slack. Would running leaner increase the idle? That doesn't seem likely.
        • 9981
        Have you syncronized the carbs?
        • LoHo
          • Sep 2002
          • 1342
          • Fresno, CA
          I have synched the carbs.
            • 9981
            A hanging throttle or carbs out of sync are about the only things that'll cause a high idle. A vacuum leak(s) could cause it under the right conditions but it's not very likely with a carbureted engine.
              • 9981
              JAT......disconnect the throttle cable frome the carbs and see if it makes a difference.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                • Fort Myers, Florida
                Carbs
                before you put the carbs back on the bike did you do a visual check to see if all 4 close completly and at the same time? If they all will close completly with the idle screw out, then you have a vacuum leak with or without a fuel bleed through the choke linkage JIMHO
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  Bench sync, or on the bike while it's running? High idle will be pretty normal with a bench sync....
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    +1 Steve, IMHO bench is just to get the bike running again, worthless for anything else
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • LoHo
                      • Sep 2002
                      • 1342
                      • Fresno, CA
                      Carbs were synched on the bike.
                        • 9981
                        At 1900 RPM?
                        • LoHo
                          • Sep 2002
                          • 1342
                          • Fresno, CA
                          Well, not exactly. It ran rougher at lower rpm until they were all even. As I synched 1/2 to 3/4, the rpms climbed and stuck around 18-1900.
                            • 9981
                            I'm going to go out on a limb and say that's where your problem is. You can't properly sync carbs above about 800RPM.
                            • LoHo
                              • Sep 2002
                              • 1342
                              • Fresno, CA
                              I believe you...but since the master adjuster is fully open, how do I get the rpms down to do it properly?
