Fired up the Alpha bike yesterday. Started in a heartbeat. Then I uncovered the Special and proceeded to see if I could get some plugs to spark. After awhile managed to get a healthy spark on #1 cylinder but it only sparked just as I released the starter button, not while it was cranking, several times it would do this, thought that was kinda odd! Anyway, I have to replace 3 fuses and one fuse bracket, these old fuses I dunno, the glass tubes become unglued from the metal ends, the fuselink itself detaches from the ends, they sure dont stand the test of time......Once I replace the fuses and check my voltages go at it again tomorrow. Mean while managed to get the horn and signal switch cleaned up and working plus 3 signal lights and the the instrument cluster ......woooooeeee, what progress. Glad I enjoy this tinkering!
Once I get all the plugs to fire up, then into the carbs.....then the corroded calipers, then.....well you know how it goes!
Bruce
78 XS1100
79 XS1100 Special
Bruce
78 XS1100
79 XS1100 Special
