Am I doomed? Broken casing....
  • Intro2pete
    • Jan 2013
    • 14
    • Lewisham, England, UK
    What do you think?
    79 SF
  • jayel
    • Apr 2012
    • 152
    • Birmingham, Iowa
    long way from its heart, fill it in with JB Weld.... remove the screw put a light coat of oil on it and put it back in, patch broken area with the JB, don't mess with it until it sets up then the oil should allow the screw to be removed... if you're good you can make a form with masking tape to match the case profile if not you can file/sand the JB down later... other way is to remove screw and fill but then you have to drill and tap threads (see you're acrossed the pond do you have JB weld over there? or equivalent)
    where are we going, and why are we in this hand basket?
    Iowa the Beautiful Land 1980 XS1100SG
      I think that sucks, but you can still keep riding. That's the timing cover, and since there is no oil behind it, you don't really need to worry about a perfect seal. The other bolts on the cover will keep it in place just fine.
      • Intro2pete
        • Jan 2013
        • 14
        Phew - that doesn't sound too bad, I'll give that a go once I get around to pulling it all apart! Thanks guys.....
        79 SF
          I have a similar situation on the alternator cover of my SH. I have been thinking of repairing it with JB Weld or similar for years, about 7,000 miles of riding now. Still have not gotten that round-to-it. Runs fine as is.
            • 2091
            If you still have the piece that broke off just glue it back on with JB Weld or an equivalent. Just be wary of torqueing it too tight.
            It's primarily a cosmetic repair.
              Originally posted by Intro2pete
              - - - What do you think?
              Hi Pete,
              what did that is replacing the stock fastener with a stainless fastener that's too long so it bottomed out and bust the casting. Check all the other fasteners for length before it's too late.
              And nah, you are merely aesthetically challenged.
              Like the 'Bug sez, that cover only keeps the dust out.
              What I'd do if I couldn't stand to look at the broken area is cut the casting away so the damage don't show, cut the cover to match and give the area a good polish.
                • 5069
                JB Weld that I have used in the past will soften if the temperature get too high. It probably wouldnt be an issue at that location though...maybe. That is what I would try. What about that liquid weld stuff?
                  I've used their Steel products to repair a headlight housing on an old car, it was the popup type of housing, worked great, held up just fine. Cures much faster than JB Weld, and with particles of aluminum mixed in it, it's pretty strong!
                  • jayel
                    • Apr 2012
                    • 152
                    • Birmingham, Iowa
                    JB is good to over 500 degrees, so that leaves out your exhaust pipes and the combustion chambers anything else getting that hot on your bike would be its own problem... JB has steel powder in it
                    • desert1
                      • 750
                      • Grand Desert, Nova Scotia, Can.
                      Aluminum or jb weld
                      Intro I had the same issue at one point in another engine.....I used the aluminum product as TC pointed out, only thing I can add is that I drilled a few holes in the casing with a 1 MM drill bit to allow the aluminum to anchor better........good luck
                      Bruce Doucette
                      78XS1100 still out there and running strong!
                      Bruce Doucette
                      Phone #1 902 827 3217
                      • Intro2pete
                        • Jan 2013
                        • 14
                        Thanks guys. That drilling idea sounds like a good suggestion, much better than a new lump of something to fall off later.
                        79 SF
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Casing Repair
                          If you know or can find a good welder - one who can weld aluminum (heliarc), that is another way to repair the case. Weld are can be reshaped after completion. Would drain oil prior to weld.
                          MP
                          1981 XS1100H Venturer
                          K&N Air Filter
                          ACCT
                          Custom Paint by Deitz
                          Geezer Rectifier/Regulator
                          Stebel Nautilus Horn
                          EBC Front Rotors
                          Limie Accent Moves On In 2015
                          Mike
                            • 7792
                            Sorry, but I've welded an old XS case, and it's NOT going to work as well as the stuff TC shows. The oil in the casting keeps the weld from being clean, and there is NO WAY to get the oil out. I used a TIG, AC, for welding on Special Eds left rear motor mount. It worked, but was NOT pretty. JMHO
                              Hi Mike,
                              removing the oil is only the first step. Next, dismantle the engine to the bare casting and put the casting through an industrial trichloroethylene vapor degreasing tank.
                              Welding only works on aluminum castings if they are really, really clean.
