Okay, I've finally got enough motivation to go ahead and lap the valves on my SG.
I swapped the heads with my G a couple months ago, so the SG head is sitting on the carport floor.
(the reason why I swapped heads was because I have a low compression problem on the SG (#1,2) and I thought it was the head/valves, but it might be a bad head gasket. I don't think it's the rings because the compression numbers didn't change much after adding some oil in the spark hole)
I've been reading up as much as I can find on lapping.
I guess the first thing I should check is: to fill the intake (and exhaust) ports with some 'solvent' and see if the valves even leak by or not.
When I first got the bike, #3 exhuast valve was bent, so I got a new one in there, but didn't bother to check to see if it seated 100%.
So, with the G's head on the SG, I still have poor starting and marginal performance. (like before)
Okay, I'll order a new head gasket. (anyone know where to get one for a good price)
so not high risk. Cyliner head gaskets on the other hand are multi part metal clad gaskets working under much greater pressure. Less likely to work a second time. Engine suffers if it fails and much more difficult to replace therefore much higher risk to not replace it.
SO...I just lapped it in and was able to obtain the same 1/16th or 1/8th" gray line all the way around the valve and valve seat. It's been over 10 years, and it's been holding up great with over 16K miles. I also lapped all of the other valves/seats as well.
