new girl in town
    #46
    No, not really. The main issue with these is on the early 650s, Yamaha added a too-small starter to them that didn't really have enough poop to start the motor reliably (hence the compression release) so you'll end up kick-starting it on a fairly regular basis. The XS-1 bikes were kick only, the later bikes got better starters.
    My XS-2 was one of the more reliable bikes I ever owned, and the only one that you could do all regular maintanence on (valve adjustments, set the timing, etc) with the supplied tool kit (with the addition of a point file and feeler gauges to the kit).
    You might want to swap the points out for the later electronic ignition..
    • Cuda 69
      • Jan 2012
      • 676
      • Greenwich N.Y.
      #47
      welcome to the sight Allie,a bunch of good people here.I also will be looking for an xs650 to add to my 11 special sometime in the future.Good luck with the build.
      FOXS-XS11SG
      1980 XS11SG-sold
      1999 Vulcan classic-sold
      1982 XJ 650-sold
      • Ncbikebabe
        • Jan 2013
        • 23
        • Asheville NC
        #48
        thanks! just gotta decide which one to start on lol.
        • conquest87tsi
          • Jun 2012
          • 190
          • Jackson, Minn.
          #49
          Do the 650 first. Maybe I'm just tired of working on my 1100, or it could be that I really want a TX650.
          1979 XS1100 SF
          1979 XS750 SF
          Previous Rides:
          1981 KZ650CSR
          2006 VTX 1300C
          1986 Radian 600
            • 8062
            Hey Steve! I have an '83 XS650 and it's electric foot isn't so great either. I think the starters are actually all the same from the XS-2 forward. I think the mothership decided the compression release wasn't necessary. I use the electric foot only after it's warmed up.
            It's a 72. Is that a bad thing?
            An XS-2 can bring a nice chunk of change if it's a complete original or restored to original. Cut-up, it's just like any other cut-up XS650.
              #51
              Hi Allie and welcome,
              4 pages of posts in 3 days, wow. Where to start? At the front of your XS11. Compared to modern bikes the XS11 forks are frail and wobbly, best you put the front fender back on, it also acts as a fork brace. Further improve the fork by adding a TKAT fork brace. Best $100 I ever spent.
              Now to the back end. I'm so effin' old I spent my first 5 years riding rigid frames because those pre-war bikes were just affordable clunkers back then, not the priceless antiques they are now. Oh how I lusted for a bike that had rear suspension. My back still hurts just thinking about how hard those old bikes rode.
              Unless you want the bike to be an unrideable showpiece do NOT hardtail it. Your backbone will be grateful.
              On to the XS650s. They had a 14 year production run and there's lots of them out there. The older Standard models like your '72 are the most valuable so long as Sally Sawzall ain't been at them.
              If you absolutely must chop one, a late model Special will lose you the least amount of resale value.
              Great to have you on the list.
              Ride long and prosper!
                #52
                Hey Steve! I have an '83 XS650 and it's electric foot isn't so great either. I think the starters are actually all the same from the XS-2 forward. I think the mothership decided the compression release wasn't necessary. I use the electric foot only after it's warmed up..
                If I recall, mine would start on the starter if the motor caught right away (cold or hot), but if you missed the first try you ran out of battery quickly. It did tend do better hot, but I still kicked the bike a lot... I tried disconnecting the release, but there was no way without the release.
                I still remember that lever/switch 'pulsing' against my finger...
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  #53
                  Hi Allie !
                  I'm pretty new here too but have done 56 XS650 Yamaha in the last 15 years.
                  You will need some tools, electrical, compression, dip stick for final drive oil/grease level and mid drive, plus a few more for valve adjustment and carb sync/vacuum.
                  I bought a P.O. semi modified 81 LH and it's been a night mare compared to my 650s. I had a brand new 1979 XS1100FS but back then changing oil, plugs and valve adjust was about all I was into. Good for me 56000 miles before I sold to a bud with only help from another bud when on of the fuse holders broke.
                  Not trying to scare you but take your time, ask first and do what you do right the first time, ask this list they helped me with my newly arrived 1981.
                  I'll help if I feel I'm up to it depending on what it is ?
                  Don };~)
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
                  • tweeleft
                    • May 2009
                    • 110
                    • Bend Oregon
                    #54
                    Hello
                    Liked ALL the pics. Looks like a 79SF Welcome
                    Keep the shiny side up
                    1979 XS1100SF
                    Mac 4-1
                    Drilled airbox Uni filter
                    Vmax bars
                    Virago 1" shorter shocks
                    30K miles
                    http://i1228.photobucket.com/albums/...429_135845.jpg
                    1981XS1100SH
                    '80 G Forks and Triple Tree
                    '80 G tank
                    Mac Turnouts
                    Virago 1" shorter rear shocks
                    SH Headlight
                    http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                    61 Wife
                    83 Son
                    86 Son
                    89 Daughter
                    • mmatches1
                      • Sep 2012
                      • 121
                      • Alberta, Canada
                      #55
                      I picked up a 1979 XS this past summer with a touring package and plan to convert it into a custom unit. I have stripped the speedo and tach unit and will install a single speedo. I also have to install a new wiring harneess and headlight amont other things.
                      Good luck with the project.
                      81H Venture - hope to ride summer 2013
                      79F Cafe Racer at Some Point;
                      68 CB175 Sloper - Cafe Racer
                      74 KZ400 - Restoration project nightmare
                      62 BSA Super Rocket - In Pieces
                      72 CB100 Super Sport - Not super or sporty but fun
